GTEASER Posted February 3, 2017 Share Posted February 3, 2017 (edited) Sticky for all DIY threads or posts created by various users. PLEASE NO COMMENTS OR QUESTIONS, THIS THREAD IS FOR INFO ONLY. Edited August 14, 2017 by GTEASER GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
GTEASER Posted February 3, 2017 Author Share Posted February 3, 2017 Clutch Replacement (transmission drop method) http://legacygt.com/forums/showthread.php/diy-clutch-replacement-trans-drop-259740.html Thanks mijophil!!! GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
GTEASER Posted February 3, 2017 Author Share Posted February 3, 2017 Clutch Replacement and Engine Pull http://legacygt.com/forums/showthread.php/engine-pull-walk-thru-errr-talk-thru-258809.html?t=258809 Thanks FLlegacy!!! GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
JLGT Posted February 3, 2017 Share Posted February 3, 2017 Front Bumper Removal (2010+) [DIY] Headlight Removal (2010+) [DIY] Crank Pulley Removal and Install (2010+) [DIY] In Cabin Filter Change - 2010+ [DIY] Throttle Body Coolant Bypass. Link to comment Share on other sites More sharing options...
islandborn Posted February 3, 2017 Share Posted February 3, 2017 Fuel pump removal and replace http://legacygt.com/forums/showthread.php/deatschwerks-dw300-fuel-pump-install-181399.html?t=181399&highlight=fuel+pump Link to comment Share on other sites More sharing options...
DrD123 Posted February 4, 2017 Share Posted February 4, 2017 (edited) Headlight replacement without pulling bumper http://legacygt.com/forums/showthread.php/5th-gen-lowbeam-headlight-replacement-231911.html Edited November 8, 2017 by Zee199969 Link to comment Share on other sites More sharing options...
BBPeik Posted February 4, 2017 Share Posted February 4, 2017 (edited) Injector swap walkthrough. Not the best but I hope it helps http://legacygt.com/forums/showthread.php/injector-swap-tutorial-252224.html?t=252224&highlight=injector Edited November 8, 2017 by Zee199969 My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
BigBopper Posted February 20, 2017 Share Posted February 20, 2017 (edited) A few pics of disassembly for reference. Edited March 11, 2017 by BigBopper Link to comment Share on other sites More sharing options...
Humble Rumble Posted March 10, 2017 Share Posted March 10, 2017 Guide To Swapping to LED Turn Signal Relay Guide applies to both simple LED flasher relay and TapTurn/SmartTap smart modules Since an LED bulb draws so much less power than a halogen, it makes the car think the bulb is burnt out, causing your turn signals to blink extra fast. This relay fixes that issue. 81980-50030 is the basic relay you can use for this, which you can find here-> Simple LED Relay Guide Pictures Walkthrough Credit to testa422 for walking me through this the first time. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
Timothy.B Posted March 14, 2017 Share Posted March 14, 2017 3.6R Spark Plug Replacement http://legacygt.com/forums/showthread.php/3-6r-spark-plug-replacement-256538.html Timothy.B's 2011 LEGACY 3.6R Link to comment Share on other sites More sharing options...
GTEASER Posted August 14, 2017 Author Share Posted August 14, 2017 Just want to put this somewhere to archive it. Thanks to Captain Ned for the info. VF54 Turbo coolant pipes. Had the turbo coolant lines replaced today. I'd show you pics of the dead ones, but when the tech went to take them apart they basically collapsed into rusty dust in his hand. I was one good pothole away from a total coolant loss and turbo burn-up. Oi!! My LGT has (had, now traded) 142K miles and 6 VT winters. Anyone here who lives in winter salted-road territory should brave a trip to the dealer to have the turbo coolant lines inspected. The engine you save may be your own. These are the special order parts needed to do the job, and they take about 3-4 weeks to come in: 14430AA220 PIPE COMPLETE-TURBO,NO.2 1 14472AA250 HOSE ASSEMBLY-WATER 1 14480AA010 CONNECTOR-TURBOCHARGER PIPE 1 15194AA100 SCREW-UNION 2 803912040 GASKET 4 803912130 GASKET-12.5X17X2 1Just in case, that last figure is the quantity needed. Got a couple of PMs asking about it, so just making sure And if you decide to go with the alternative, the Kinugawa kit, you need the extra Subaru spacer. Thanks Shadow_419. Connector turboo pipe 14480AA010 Turbo 6AN Water Coolant Line Kit M12x1.25 mm TD02 TD03 TD04 banjo type 320-12001-015 GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
jojorios Posted August 15, 2017 Share Posted August 15, 2017 Here's a pic that Shadow_419 posted as reference to how it all comes together with the spacer. http://legacygt.com/forums/showpost.php?p=5552098&postcount=835 Link to comment Share on other sites More sharing options...
GTEASER Posted September 12, 2017 Author Share Posted September 12, 2017 LGT Spark Plug Replacement - special thanks to minuccims for this thread and the contributors that added great info. http://legacygt.com/forums/showthread.php/lgt-spark-plug-replacement-171731.html?highlight=spark+plug GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
GTEASER Posted October 11, 2017 Author Share Posted October 11, 2017 DIY Rear Chassis Ground Thanks to covertrussian for this. http://legacygt.com/forums/showpost.php?p=5699116&postcount=91 This is why it is preventative maintenance.... http://legacygt.com/forums/showpost.php?p=5698652&postcount=86 Refering to your bearings damage.... From what I know... it similar like the "Stray Current Bearing Damage" issue in electric motor http://www.ecmweb.com/content/bearing-current-problems-causes-symptoms-and-solutions Even I am aware about this "stay current" issue.. I did not expect this would happen to car wheel bearing as well.... By the way... thanks for sharing this info on bearing failure... Sent from my SM-G930F using Tapatalk I believe it is similar to "Stray Current Bearing Damage" too, but our fluting is not quite as consistent as an electric motor's. Though this could be because we don't run our wheels at same speed all the time. It's an interesting phenomenon, when I first read the theory I laughed and chucked it off, but after having to replace two rear and one front wheel bearing on my LGT at ~100k, I regrounded my whole car. My one left front lasted another 40k, and I recently replaced it for good measure . I think our high throw out bearing failure is related to this too. If you think about it, stray current would be going through it from the engine to the transmission. For those that are curious, that's referring to my 2014 thread when I first discovered this issue: Bad Grounds Can Lead to Wheel Bearing Failure I agree with you.... the stray current phenomenon in constant speed induction AC electric motor may not 100% applicable to our bearing failure... In AC electric motor.. the worn damage cavities (that look like welding on the bearing inner race circurmference) is in full circurmference of bearing inner race... whereas in your wheel bearing the damage is on the opposite (not full circurmference). One thing that might contribute to this.... could be the atmospheric environment as well... I see on your photo.. a lot of corrosion throughout the whole places on your car... The car was built 2012 right? Mine 2012 LGT BM9 with 7+,+++km, but mine doesn't have any sort of that kind corrosion issue.. event my 1993 Civic EG3 is same too. I live in tropical climate always 3+degC with dry humidity & not near to the beach. Therefore.... I believe atmospheric condition (temp variation between season, humidity, present of salty environment) really play significant roles with corrossion + your bearing failure... Bear in mind...if we refer to corrosion engineering point of view: 1) In salty + humid environment the air become conductive for electrolisis process (similar to battery concept) 2) Plus with 2 disimilar material/metal joint/touching each other (in our case... bearing & its housing) 3) The resultant could result the same phenomenon as anodic/galvanic corrosion Refer to this article at the bottom page: http://www.dootalk.com/forums/topic/1292626-very-good-read-on-bearing-failures/ Sent from my SM-G930F using Tapatalk GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Zee199969 Posted April 8, 2018 Share Posted April 8, 2018 GT Timing Belt Service part numbers Thanks dgoodhue! My "Build" Link to comment Share on other sites More sharing options...
GTEASER Posted April 12, 2018 Author Share Posted April 12, 2018 EJ253 (2010-2011 2.5i) Engine Swap Thanks to reeg420!!! http://legacygt.com/forums/showthread.php/2-5i-motor-swap-diy-269227.html GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
GTEASER Posted June 6, 2018 Author Share Posted June 6, 2018 (edited) Sunglass Holder replacement latch. https://www.homedecorhardware.com/sugatsune-pr-3pk.html Credit to one of the guys in the FB group. Edited June 9, 2018 by Zee199969 GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Zee199969 Posted June 9, 2018 Share Posted June 9, 2018 (edited) Lumbar Support Fix dunno why it took me this long to post it up, but thanks TheCopyCat! Edited June 9, 2018 by Zee199969 My "Build" Link to comment Share on other sites More sharing options...
