VespaGTS Posted May 22, 2019 Share Posted May 22, 2019 Hi Guys, Like the title says I have a bulb seating issue. I purchased a set of JDM Astar turn signal bulbs for my JDM headlight conversion corners. The bulbs do not seat well into the socket. They fit well, but there is no positive click and with very light pressure will fall out. Is there a difference in the turn signal bulbs between USDM and JDM? If you have JDM headlights what bulbs have you used for turn signals that fit well? Thanks! Link to comment Share on other sites More sharing options...
DoctorDaveLGT Posted May 22, 2019 Share Posted May 22, 2019 7440/7443 bulbs for the JDM turn signals, USDM is a 3157 bulb. In the past and not related to the JDM headlights, I've purchased LED signal bulbs that just didn't seat well for whatever reason and used electrical tape to keep it secure. Not ideal if visible through a clear lens as the tape can be seen. Link to comment Share on other sites More sharing options...
VespaGTS Posted May 22, 2019 Author Share Posted May 22, 2019 Thank you for your advice DoctorDave! Link to comment Share on other sites More sharing options...
