Jags Posted November 24, 2020 Share Posted November 24, 2020 Looking for an engine replacement for my 2009 Legacy, have a blown block I have found an engine that may fit for my 2009 Legacy but I just want to make sure that it will fit 100% https://www.ebay.com/itm/06-07-08-09-2010-SUBARU-LEGACY-OUTBACK-FORESTER-RS-2-5L-ENGINE-JDM-EJ25-EJ25DE/254781183119?hash=item3b5224548f:g:gs8AAOSwrhNckUK4 Link to comment Share on other sites More sharing options...
Max Capacity Posted November 24, 2020 Share Posted November 24, 2020 (edited) 'm thinking that JDM is not going to work well for you. I'm no expert but may be someone who is will chime in. I see someone else is asking the same question. https://www.subaruoutback.org/threads/will-this-engine-fit-my-09-outback.526956/ Edited November 24, 2020 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted November 27, 2020 Share Posted November 27, 2020 there's a compatibility chart on the link.... tells you exactly what it fits. Link to comment Share on other sites More sharing options...
boxkita Posted November 27, 2020 Share Posted November 27, 2020 OP, unless you bot it already, that option is no longer available Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Protegejustin19 Posted November 30, 2020 Share Posted November 30, 2020 jdm is the cheapest option by far Link to comment Share on other sites More sharing options...
boxkita Posted December 1, 2020 Share Posted December 1, 2020 swapping a jdm engine seems simple but it never is. It's not the purchase price that kills ya, its everything else. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Max Capacity Posted December 1, 2020 Share Posted December 1, 2020 Ditto ^ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted December 2, 2020 Share Posted December 2, 2020 its a 2.5 sohc! the issues with the jdm usdm swap for us gt guys is when they try to swap a 2.0 into our 2.5 setups. For what this guy is doing , its pretty much the same motor. Link to comment Share on other sites More sharing options...
dgoodhue Posted December 2, 2020 Share Posted December 2, 2020 I don't know the difference between the JDM and USDM 2.5i. The key would be make sure the camshafts, heads and compression ratio are the same for the motor being removed and it has AVCS. If you are going to have to start swapping those parts around, you might as well get a new $1800 short block from Subaru. Tuning 2.5i is not that common so you want something matches up, not some that is close enough that you can tune it out. Link to comment Share on other sites More sharing options...
blackobxt Posted December 2, 2020 Share Posted December 2, 2020 (edited) The last issues I had with installing a customer supplied jdm ej sohc was the jdm didn’t have egr or provisions for it, just a blank boss. Customer said he was ok with a cel, I used the usdm intake manifold and wiring harness and plugged the egr port on it and out the door it drove. I don’t think it spent even 2.5hrs in my bay. Edited December 2, 2020 by blackobxt Link to comment Share on other sites More sharing options...
