Max Capacity Posted July 20, 2020 Share Posted July 20, 2020 Cracked head, they didn't just weld it up ? The race head on the Civic was the Head that Zex Nitrous Systems used to develop there system. It had extensive work done to it and had been repaired a number times from valves being stuck in it. Those single cam 1.6L engine were known to have #3 cylinder issues 25 or so years ago. Every time that Head needed work it went back to Brad at RLZ Race Engineering in, I think it was NC. He was on speed dial... LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted July 20, 2020 Author Share Posted July 20, 2020 (edited) the crack isn't visible from the outside, when I pulled the head, I didn't see anything wrong which had me baffled. I have the old head and just now I tried looking for the crack to see if if a weld was possible but still don't see it. Its internal, can't weld what you can't see. I would rather pay 300 bucks for a used head, rebuilt and reinstalled than to have it welded, I paid for head, and he ate the labor costs. The machine shop i used gave me a really good price for the original work, so I'm not complaining, the guys honest to a fault so it's hard to be upset lol. I couldn't see the crack either, initially I told him the heads were good the first time it was rebuilt, so I doubt they could see the crack as well without doing serious investigation, I can still see the red dye they used to track down the crack, but it is in there. You need a scope to see it. I got a good price for work because I tore everything down, and asked just to reassemble, I only asked him to inspect the valves and replace as necessary. All together i'm at like 2k total for labor and rebuild of the longblock. Edited July 20, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Max Capacity Posted July 20, 2020 Share Posted July 20, 2020 Glad you got the issue taken care of and are happy. I most likely would have done the same thing as you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted July 21, 2020 Author Share Posted July 21, 2020 (edited) Finished the front suspension, will get to the rear tomorrow. Edited July 21, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Tehnation Posted July 22, 2020 Author Share Posted July 22, 2020 buttoned up and finished the rear suspension today Link to comment Share on other sites More sharing options...
Tehnation Posted July 22, 2020 Author Share Posted July 22, 2020 Some pics of the engine, fuel pump wiring and rear brace. Link to comment Share on other sites More sharing options...
Tehnation Posted July 22, 2020 Author Share Posted July 22, 2020 (edited) Next I am going to do the sti fpr mod, and fpr vacuum line mod. Info in link below, excellent write up! Worth the read for anyone with the stumble. I'm doing the mod because I can't stand this big piece of complicated crap we have. Save some room, makes things a lot easier, and can see your fuel pressure without disconnecting , because for some reason subaru doesn't believe in schrader valves. Will make it easier to install an aftermarket fpr if needed in the future as well. https://legacygt.com/forums/showthread.php/install-04-07-sti-fuel-pressure-regulator-fpr-and-use-263825.html Ordered : inline fuel pressure gauge https://www.amazon.com/gp/product/B01GQNVDDW/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 gauge adapter https://www.ebay.com/itm/5-16-Barb-8MM-fuel-pressure-gauge-adapter-with-1-8-NPT-port/184199811997?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 sti fpr Subaru part# 22670AA351 https://www.amazon.com/gp/product/B00I799IFY/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 2 x turkeylord tees from company 23, amazon sells one for 20 bucks, and you can get 2 for that price straight from manufacturer, they are 8 or 9 dollars a piece! https://legacygt.com/forums/showthread.php/subaru-blue-tee-replacement-218783.html http://www.company23.com/VacuumT Got these assortment of clamps and spring clips as well https://www.amazon.com/gp/product/B07HJ2X5LK/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B075LDN3T7/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 Edited July 22, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Tehnation Posted July 22, 2020 Author Share Posted July 22, 2020 But thats for the future first I have to deal with this leaking heater core .... so I have to pull the dashboard change the heater core, then put my entire interior back together.... For some reason I find this work 100x's worse than everything else, I've been sooooo dragging this out to avoid it, but now everything else is done.... Link to comment Share on other sites More sharing options...
Tehnation Posted July 22, 2020 Author Share Posted July 22, 2020 (edited) Some older pics of the rotors, ss lines, new calipers, and my cheap coilovers. 10 gauge wiring for fuel pump, 0 gauge wire for amps and fuel pump, and some random stuff. Edited July 22, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Tehnation Posted July 22, 2020 Author Share Posted July 22, 2020 Link to comment Share on other sites More sharing options...
Tehnation Posted July 22, 2020 Author Share Posted July 22, 2020 the old cracked head... can you see the crack ? Link to comment Share on other sites More sharing options...
Max Capacity Posted July 23, 2020 Share Posted July 23, 2020 Sorry, I can't see the crack. That's a lot of work you've done there recently. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted July 23, 2020 Author Share Posted July 23, 2020 I didn't expect anyone to see it, especially when I'm holding it in my hands and don't see it lol. I'll chalk it up to the subaru gods, I haven't given them offerings in a long time, so it was overdue! i went through like 10 shirts over 2 days, sooooo hot outside.... I have to come up with a game plan to pass inspection after registration, i can't drive the car to tuner until it gets both things, and it wont pass inspection without the tuner.... i know check engine lights are going to come on... Link to comment Share on other sites More sharing options...
Infosecdad Posted July 24, 2020 Share Posted July 24, 2020 I would think the tuner should be able to send provide a base map for basic driving without CELs. Link to comment Share on other sites More sharing options...
Tehnation Posted July 25, 2020 Author Share Posted July 25, 2020 i would hope so lol! Dashboard is loose , looks like all the bolts are out, but the steering wheel.... i'm going to have to remove it. Link to comment Share on other sites More sharing options...
Tehnation Posted July 26, 2020 Author Share Posted July 26, 2020 dashboards out.... windshields now cracked... Things to add to the list: New windshield.... Looks like getting the dash out is only like 25 percent of the battle.... getting to the heater core is an entirely different animal... Link to comment Share on other sites More sharing options...
Tehnation Posted August 2, 2020 Author Share Posted August 2, 2020 interior is done, mostly, just need to setup amps and subs in trunk etc. and put on the rear seat. Link to comment Share on other sites More sharing options...
awfulwaffle Posted August 3, 2020 Share Posted August 3, 2020 Can't see the crack either. Did someone try to port those heads? Link to comment Share on other sites More sharing options...
Tehnation Posted August 3, 2020 Author Share Posted August 3, 2020 i don't think so, i'm assuming it was just to clean out whatever buildup was in there before. Link to comment Share on other sites More sharing options...
Tehnation Posted August 3, 2020 Author Share Posted August 3, 2020 (edited) Interior is done, seats and all. Also just finished installing the sti fuel pressure regulator with inline pressure gauge and moved the vacuum line and blocked off the one on cylinder 4. The why, in the link below. https://legacygt.com/forums/showthread.php/install-04-07-sti-fuel-pressure-regulator-fpr-and-use-263825.html Got it insured, but registration is going to be a pita because of covid, by appointment only, so I had to scan and upload all these forms. Now I have to wait for the DMV's phone call.... wow, if theres anyone I don't want to wait on its the DMV lol.... god damn covid... Also fixed my trunk release, using this guys method, I used a zip tie instead. All I have to do is connect all the wires in my trunk to my 2 amps and 12" subs to get some musak!! Edited August 3, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Tehnation Posted August 4, 2020 Author Share Posted August 4, 2020 Max, do you have a picture of the ac tag thats on the front support bar, above radiator and condenser? It has all the data for amount of refrigerant etc. Mines gone after accident. Or anyone reading! Link to comment Share on other sites More sharing options...
Infosecdad Posted August 5, 2020 Share Posted August 5, 2020 Here you go. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 5, 2020 Share Posted August 5, 2020 Max, do you have a picture of the ac tag thats on the front support bar, above radiator and condenser? It has all the data for amount of refrigerant etc. Mines gone after accident. Or anyone reading! I thought about getting a picture for you, but you do know what was going on last evening about that time, Hurricane Isaias. It was kind of windy around here. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted August 5, 2020 Author Share Posted August 5, 2020 i was outside working on my car lol Link to comment Share on other sites More sharing options...
Tehnation Posted August 5, 2020 Author Share Posted August 5, 2020 Had to order a new amp, my 4 channel which was powering my 4 speakers seems to be shot. Got this amp, excellent price, good brand. https://www.crutchfield.com/p_236THND754/MTX-THUNDER75-4.html?tp=115 I was out in the storm trying to setup some sound, and putting some vacuum on my ac system. Hopefully there is still vacuum on the system when I check it later tonight. How was it by you, my house still has power. My city was a mess, it was like a maze to get out to the main roads, power lines down everywhere. Link to comment Share on other sites More sharing options...
