iNfEk Posted April 17, 2019 Share Posted April 17, 2019 Bought a AVO380 turbo that was remanufactured but it didn’t come with the necessary hardware. I have a NW rally oil feed line that goes from the AVCS area to the turbo with standard banjo bolt and copper washers. The turbo according to the place I got it from said I needed a 4AN that is restricted to 1mm. Is this just a fitting that goes onto the turbo and then the banjo bolt goes into it like normal or do I need a different banjo bolt? Going on a trip and when I come back I’ll need to put the 05 LGT back together ASAP! What else do I need to run this stock location turbo? Link to comment Share on other sites More sharing options...
Max Capacity Posted April 17, 2019 Share Posted April 17, 2019 google is your friend, will this help ? https://www.google.com/search?q=1mm+restrictor+in+a+%234+AN+fitting&oq=1mm+restrictor+in+a+%234+AN+fitting&aqs=chrome..69i57.19518j0j8&sourceid=chrome&ie=UTF-8 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Kazanjion Posted April 21, 2019 Share Posted April 21, 2019 I'm interested to see what you get out of your 380. I just got one myself. Are you running a FMIC? Link to comment Share on other sites More sharing options...
Code Posted April 21, 2019 Share Posted April 21, 2019 https://www.atpturbo.com/mm5/merchant.mvc? This is what you need. The AVO380 is a Garrett chra I have been using this turbo for a few years. 21 psi peak. 18psi at redline. It pulls hard. I’ll have a flex Fuel tune on Thursday and I will update you guys with a chart and some numbers. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
Kazanjion Posted April 22, 2019 Share Posted April 22, 2019 It's a disco patato pretty much right? But with ceramic ball bearings. And a stainless exhaust housing if you get the v2. Link to comment Share on other sites More sharing options...
Code Posted April 22, 2019 Share Posted April 22, 2019 It’s a 2871R with LGT cold side housing. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
iNfEk Posted May 2, 2019 Author Share Posted May 2, 2019 Thanks guys. I ended up buying a Kinugawa oil feed line that connects to the factory hardline and supplied the proper adapter to the turbo and line. Since buying the AVO380 It’s gotten installed but the turbo threads to intercooler now need repair -_- so ended up stumbling on an old thread here for a possible solution. Link to comment Share on other sites More sharing options...
