P&L rails and lines - full evap delete questions
There are two solenoids on the front of the engine. One by the boost control, and one on the driver's side behind the A/c compressor. Can I remove both of them? Buttoning everything up, just wanted some suggestions. I searched but only came up with vague answers, mostly for the 05/06.
Thanks in advance!
Also, do I need the flow/filter from the MAP to the intake manifold? Can I just run a vacuum line?
There are 2 purge/vent solenoids on these cars from 07/08 up. One is by the boost control solenoid, the other is right behind the a/c compressor. I removed both completely. Confused me at first because there were 2 and the factory lines were not in place (sold them) the factory vent goes to the hard lines and T's to the two solenoids. The one behind the A/c vents to the intake manifold, the other to the inlet.
As far as I have researched, the codes can be removed by any tuner.
