pjcampbell Posted September 10, 2019 Share Posted September 10, 2019 Does anyone know if the 5x100 45mm offset Sparco Terra's in a 15" diameter will fit a 2005 Outback? (I.e. will they clear the brakes): https://www.tirerack.com/wheels/WheelCloseUpServlet?target=runWheelSearch&autoMake=Subaru&autoModel=Impreza+2.5RS+Wagon&autoYear=2005&autoModClar=&initialPartNumber=W29070004MB&i1_Qty=4&wheelMake=Sparco&wheelModel=Terra&wheelFinish=Black+Painted&wheelFinish=Black+Painted&showRear=no&packageFlow=false Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 10, 2019 Share Posted September 10, 2019 I believe the smallest diameter which will clear our brakes is 16". Link to comment Share on other sites More sharing options...
pjcampbell Posted September 10, 2019 Author Share Posted September 10, 2019 Certain 15's fit on a NA Outback (not sure if XT brakes are bigger?) I'm just not sure if Sparco Terra are one of them. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 10, 2019 Share Posted September 10, 2019 According to cars101, na: front: 11.5 x.94 ventilated twin caliper piston xt: front: 11.5 x 1.18 ventilated disc, twin caliper piston Looks like they only differ by the rotor thickness. That may result in different caliper size too. http://www.cars101.com/subaru/outback/outback2005.html Link to comment Share on other sites More sharing options...
dukeneverwinter Posted September 18, 2019 Share Posted September 18, 2019 Not 15s but I have the 16" Sent from my LG-LS997 using Tapatalk Link to comment Share on other sites More sharing options...
pjcampbell Posted September 19, 2019 Author Share Posted September 19, 2019 sorry yeah I tested the 15s , they don't fit with standard backspacing (40-45mm). You need 15mm which makes them stick out far, and to me looks poor. The only ones that fit now as far as I know are going to be Method VT Specs. Link to comment Share on other sites More sharing options...
dukeneverwinter Posted September 19, 2019 Share Posted September 19, 2019 Braid may make something that fits also. Rally specific, so may be more expensive than Method also. Sent from my LG-LS997 using Tapatalk Link to comment Share on other sites More sharing options...
pjcampbell Posted September 19, 2019 Author Share Posted September 19, 2019 I spent 72 dollars testing wheels (return shipping) from TireRack so I'm done now, i'll order Methods when I'm ready. Link to comment Share on other sites More sharing options...
