timmie415 Posted September 28, 2020 Share Posted September 28, 2020 (edited) UPDATE: Thanks to DaveWaters pointing out that I might have a faulty gauge. New numbers are: Cylinders 1, 2 and 3 cold compression 100 Cylinder 4 was 55 dry and 75 wet. Will be researching ringlands and deciding if this is a job I want to tackle myself or outsource it. Thanks and sorry about the phony title. -Tim Edited September 30, 2020 by timmie415 updated data Link to comment Share on other sites More sharing options...
blackobxt Posted September 28, 2020 Share Posted September 28, 2020 Going to be hard to tell without a leakdown. But it could be anything from broken pistons to burnt valves or a super bad headgasket. Link to comment Share on other sites More sharing options...
timmie415 Posted September 28, 2020 Author Share Posted September 28, 2020 I agree that without that data this is a hard nut to crack. I might have to ask my significant other to reach out to her coworker's husband who might have the right tools... In the meantime I welcome all other advice and responses! Link to comment Share on other sites More sharing options...
Max Capacity Posted September 28, 2020 Share Posted September 28, 2020 I hope you have replaced that 16 y/o timing belt ? When you get the leak down #'s let us know. I guessing you need a new short block. Also can you please increase the size of your "font" I find that small print hard to read. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DaveWaters Posted September 28, 2020 Share Posted September 28, 2020 From what you’re describing with the compression test. That it hit 90 but didn’t hold pressure. I’d source a different tool, sounds faulty, as the tool is what holds the pressure. Honestly at this point I think a leak down test is more in line with what you need though. Link to comment Share on other sites More sharing options...
timmie415 Posted September 28, 2020 Author Share Posted September 28, 2020 I think you might be right about the faulty tool. I attempted to get a reading on cylinder 3 and it read zero also. So tomorrow I will have to pick up a new one and will update this thread at that time. Link to comment Share on other sites More sharing options...
blackobxt Posted September 28, 2020 Share Posted September 28, 2020 Make sure the schrader valve in the end of the hose of the tester is tight Link to comment Share on other sites More sharing options...
