jcs Posted March 14, 2016 Share Posted March 14, 2016 Hi all, Finishing up my timing belt on my 2005 LGT Ltd 5MT wagon. Last step putting the belt on is to put the belt on the driver side intake (top) cam gear. This cam gear jumped a little bit CW past the timing mark. Not thinking, I just moved it back that 1/8 turn CCW. It's very clear you are NEVER supposed to move your gear BACK CCW. You are only supposed to move it CW. So.. Did I do any damage going CCW jus that 1/8 turn back. Can I put the belt on now and give it a shot? What do you do if you know you rotated that cam gear 1/8 turn CCW? Any help appreciated. Link to comment Share on other sites More sharing options...
cBax Posted March 14, 2016 Share Posted March 14, 2016 Line it up and install. You're not supposed to go other way past the resting point. When you pull it the correct way, it's open the valves in cylinders that are not at the top. It pops because of that tension. If you kept going, then youd be opening valves into pistons at the top. You're good. '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2016 Share Posted March 14, 2016 I don't believe you can damage the valves and pistons on that side of the engine because the pistons are mid stroke. #1 is at TDC, #3 is at BDC the other two are at mid stroke on the drivers side. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bugblatterbeast Posted March 14, 2016 Share Posted March 14, 2016 you are probably fine. I didn't even bother locking the cams when I did my timing belt. I let them move when I took off the belt, then just turned them back as per the instructions in the FSM. Link to comment Share on other sites More sharing options...
FJuan Posted March 14, 2016 Share Posted March 14, 2016 As long as the crank gear is aligned up to it's mark, there will be no issues. I've had mine snap back several times with no damage. You should be fine as long as the crank gear is aligned. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
jcs Posted March 15, 2016 Author Share Posted March 15, 2016 Perfect. All good. I thought it was OK because the valves snap into a closed position and all you're doing is putting them back on the cam lobe again so CW CCW shouldn't matter if the lower cam is fixed and you're just moving back from over center closed CW to over center closed CCW, if any of that makes sense! Link to comment Share on other sites More sharing options...
jwag74 Posted March 15, 2016 Share Posted March 15, 2016 As long as the crank gear is aligned up to it's mark, there will be no issues. I've had mine snap back several times with no damage. You should be fine as long as the crank gear is aligned. Mine snapped back too, as long as you line it back up you will be fine. I did it by myself having never done one previously, if I ever have to do it again I will make sure I have an extra hand or just buy the tool to hold the cams. Link to comment Share on other sites More sharing options...
discojon Posted March 18, 2016 Share Posted March 18, 2016 I just did this also when fixing a cam seal. Just don't force anything. Link to comment Share on other sites More sharing options...
