jcs Posted October 2, 2014 Share Posted October 2, 2014 Hi all, I have a 2005 LGT Ltd 5MT wagon. Just did the clutch/flywheel. Refilled transmission and reused copper gasket. The plug leaked. Torqued down to about 100 ft/lbs (rather than specified 52 ft lbs) still leaked. Purchased new Subaru gasket. Leaked again. Purchased new Subaru gasket and put teflon tape on the plug. Still leaking. So you can imagine my frustration after all the work for the new clutch, the darn plug leaks. I've drained the trans 3 times so far. Has anyone had this issue? No cracks in the threads. Car has 49,800 miles on it. Any ideas please please help! Link to comment Share on other sites More sharing options...
DonnyJagaru Posted October 9, 2014 Share Posted October 9, 2014 I'm thinking Loctite and a quiet prayer before reinstalling. Link to comment Share on other sites More sharing options...
BoozeRS05 Posted October 9, 2014 Share Posted October 9, 2014 A new copper washer or anneal the old one, should be all you need EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
apexi Posted October 9, 2014 Share Posted October 9, 2014 Dumb question but you never know.. You're certain it's leaking from the drain plug? It's not leaking down from the axle seals to the drain plug? I know when my axle seals have leaked, it leaks down the side of the transmission to the drain plug. Link to comment Share on other sites More sharing options...
compsurge Posted October 9, 2014 Share Posted October 9, 2014 It's been a while for me. Is the copper washer symmetrical top/bottom or is there a crush portion as like the oil drain? If there is a flat and a crush portion, the flat goes against the bolt and the crush goes into the threaded hole. Don't overtorque a drain bolt. It will stretch or strip the threads. Check the axle seals. And for your next clutch job, try the engine removal method. Far easier. Link to comment Share on other sites More sharing options...
Akasa Posted October 9, 2014 Share Posted October 9, 2014 Closely inspect the threads to make sure they're not all galled up. I honestly don't know what could be causing the leak... Link to comment Share on other sites More sharing options...
BoozeRS05 Posted October 9, 2014 Share Posted October 9, 2014 Good call on the axle seals. My pass axle seal has been slowly leaking forever and it runs down the trans to the drain plug, making it look like that's where the leak is. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
