davelegacy Posted March 2, 2013 Share Posted March 2, 2013 I have a 2005 legacy i, 5 spd, non-turbo, 125,000 miles. My CEL recently came on, and I brought it to my local shop that has done a bunch of work on the car. They are telling me that I need a new ECU, which is going to cost at $1,000. Has anyone had this happen? Does this seem right? The car dives fine (CEL off for now). Is that possible with a bad ECU? If I pick up a used one, do I need to re-program it before installing it? Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted March 2, 2013 Share Posted March 2, 2013 Why don't you start with telling us what the problem is, what codes are present? do you have driveability issues?.. and we can go from there Link to comment Share on other sites More sharing options...
davelegacy Posted March 2, 2013 Author Share Posted March 2, 2013 I'm not sure what code they read. I've been meaning to get a code reader anyway. Other than a cruise control that seemed very jerky for the past year (prior to CEL going on), there are no driveability issues with the car. Link to comment Share on other sites More sharing options...
Cone_Killer Posted March 2, 2013 Share Posted March 2, 2013 So the shop told you that you need to replace your ECU without reading and giving you the CEL codes.. dafuk? Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted March 2, 2013 I Donated Too Share Posted March 2, 2013 Dead ECU would be dead though... clearly not. We need that CEL code... Don't think there's one for 'I'm dead, replace me' though. Autozone etc. will read CEL codes for free. Just ask. Link to comment Share on other sites More sharing options...
davelegacy Posted March 2, 2013 Author Share Posted March 2, 2013 Thanks. I'll swing over there later today. Link to comment Share on other sites More sharing options...
davelegacy Posted March 2, 2013 Author Share Posted March 2, 2013 Ok, I missed this on the shop receipt. Code P1443, vent solinoid code. Smoke test evap system and test solinoid. Check wires and ground. ECM not grounding valve. Replace ECM. Does this make sense to anyone? Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted March 2, 2013 I Donated Too Share Posted March 2, 2013 Do you over fill your car or top it off at the gas pump? Link to comment Share on other sites More sharing options...
davelegacy Posted March 2, 2013 Author Share Posted March 2, 2013 Nope. Stop when it clicks off. Link to comment Share on other sites More sharing options...
surolegga Posted March 2, 2013 Share Posted March 2, 2013 ECM not grounding valve...but everything else works fine. Hmmm. Second opinion is worth it. Link to comment Share on other sites More sharing options...
davelegacy Posted March 2, 2013 Author Share Posted March 2, 2013 That's what I'm thinking. Link to comment Share on other sites More sharing options...
Indiglow Posted March 3, 2013 Share Posted March 3, 2013 I heard something about a faulty gas cap causing this code. def not replace ECM though, that's out of left field. Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted March 3, 2013 Share Posted March 3, 2013 I've seen it on other cars, never a subi tho Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted March 4, 2013 I Donated Too Share Posted March 4, 2013 it's all related to that blasted evap can and vent valve back there... Link to comment Share on other sites More sharing options...
davelegacy Posted March 5, 2013 Author Share Posted March 5, 2013 120 miles and no light or problems. Hmm.... Link to comment Share on other sites More sharing options...
