nospmoht04 Posted March 21, 2012 Share Posted March 21, 2012 Every since I went stage 2, or it may have been when I replaced cylinder 2 due to a broken ringland, I've been getting a crackling noise about 10 sec after I start it on a cold engine. It does it for about 15 seconds or so and stops. I'm not sure if it's the exhaust expanding, or if it's related to the cylinder job. I've got MadDad UEL headers/up pipe combo, a CNT catted DP and a Magnaflow cat-back. It's flashed to a stage 2 Cobb tune. I need a protune which I'm planning on soon. Any input/like situations? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 21, 2012 Share Posted March 21, 2012 can you make a video of the noise ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bmx045 Posted March 21, 2012 Share Posted March 21, 2012 the secondary air pumps runs for 10-15 seconds during cold starts, the engine can sometimes run rough and loud for that period and then smooth out shortly after that... Link to comment Share on other sites More sharing options...
Max Capacity Posted March 21, 2012 Share Posted March 21, 2012 the secondary air pumps runs for 10-15 seconds during cold starts, the engine can sometimes run rough and loud for that period and then smooth out shortly after that... I was going to say that. But that's a different noise then what he's describing. Nice try... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bmx045 Posted March 21, 2012 Share Posted March 21, 2012 listen grandpa, you're stage 1, things change when you actually have performance parts on. though i suggest he's overly rich Link to comment Share on other sites More sharing options...
nospmoht04 Posted March 22, 2012 Author Share Posted March 22, 2012 I can try getting a video up in a couple days, working a lot in the next few days. Yeah I'm hoping a tune will straighten it out, if it is a problem. Link to comment Share on other sites More sharing options...
nospmoht04 Posted March 22, 2012 Author Share Posted March 22, 2012 It does run at 1500 rpms at idle for a min on cold starts but this crackle noise is aside from that and clears up before it settles to a 1000 rpm idle. Link to comment Share on other sites More sharing options...
bmx045 Posted March 22, 2012 Share Posted March 22, 2012 I still think youre running super rich. The cobb maps can do that. Are you misfiring at all? Link to comment Share on other sites More sharing options...
nospmoht04 Posted March 22, 2012 Author Share Posted March 22, 2012 The only other thing I notice and it's been doing it since cylinder 2 was replaced, is I get a pretty faint knock occasionally. It's completely inconsistent and it will be up to 30 sec to a min in between. It's a light vibration and a faint knock after its been idling. It sort of skips. My father listened to it and just thought it was tune up issues. Link to comment Share on other sites More sharing options...
nospmoht04 Posted March 22, 2012 Author Share Posted March 22, 2012 It comes from the motor though, it's not an exhaust noise. Link to comment Share on other sites More sharing options...
bmx045 Posted March 22, 2012 Share Posted March 22, 2012 Okay. Who reassembled the engine and did anyone check valve lash? Over time you lash will be smaller and smaller and if you install new valves, they need to match the rest or else you'll have issues. Tight valves can tick tick and tap tap and thats not an issue but if you log roughness in that cylinder and find counts of misfire, the lash isnt appropriate. So figure you have new valves, perhaps too much fuel is entering and detonating due to improper intake and exhaust lash. This could relate to your popping sounds. Link to comment Share on other sites More sharing options...
nospmoht04 Posted March 22, 2012 Author Share Posted March 22, 2012 My father did the work, he owns a shop. The head was sent to a machine shop to be tested and cleaned, they said everything looked good. We only replaced cylinder 2. Link to comment Share on other sites More sharing options...
nospmoht04 Posted March 22, 2012 Author Share Posted March 22, 2012 I'll ask him about the valves but I'm pretty sure they weren't replaced, I wasn't there for all of it. He also did the timing belt btw. Link to comment Share on other sites More sharing options...
bmx045 Posted March 22, 2012 Share Posted March 22, 2012 The valve lash should be matched to the rest of the cylinders or atleast within subaru spec. Link to comment Share on other sites More sharing options...
nospmoht04 Posted March 22, 2012 Author Share Posted March 22, 2012 He told me the machine shop told him Everything was within spec but I don't know the extent of what they had Link to comment Share on other sites More sharing options...
nospmoht04 Posted March 22, 2012 Author Share Posted March 22, 2012 He only took off that head Link to comment Share on other sites More sharing options...
bmx045 Posted March 22, 2012 Share Posted March 22, 2012 Hmm. Try to take a video. Have you logged at all? Or learning view? Post them up Link to comment Share on other sites More sharing options...
nospmoht04 Posted March 22, 2012 Author Share Posted March 22, 2012 Yeah I'll try and get all that up this weekend. I've never data logged with the accessport so I'll have to figure it out. Put It to use before I get rid of it. Gonna take the legacy to brentuning once I get some extra money Link to comment Share on other sites More sharing options...
nospmoht04 Posted March 22, 2012 Author Share Posted March 22, 2012 Something else I just thought of, when it's popping I can gas it lightly and it'll stop, but then just settles back into it and continues popping until its done it's 15 second stretch. Link to comment Share on other sites More sharing options...
Lardo420 Posted March 22, 2012 Share Posted March 22, 2012 I have same problem. Tis the air pump sir. Come to manch Saturday am and we can start my car cold to compare Link to comment Share on other sites More sharing options...
nospmoht04 Posted March 22, 2012 Author Share Posted March 22, 2012 Hm Yeah I'm really not that far, I'm in Dover. I am pretty curious to find out what the deal is. If I don't get approved for some OT I'd probably go for a drive. Sucks I wouldn't be able to compare with a cold start but I'll take a video with my phone tomorrow morning. Link to comment Share on other sites More sharing options...
Lardo420 Posted March 22, 2012 Share Posted March 22, 2012 let me know brotato bread Link to comment Share on other sites More sharing options...
nospmoht04 Posted March 22, 2012 Author Share Posted March 22, 2012 Schweet will do Link to comment Share on other sites More sharing options...
stuck686 Posted February 12, 2013 Share Posted February 12, 2013 let me know brotato bread lol Link to comment Share on other sites More sharing options...
