DoDo1975 Posted February 18, 2019 Share Posted February 18, 2019 Just had the valves adjusted on my car (2005 Lgt) For the first time in years its running really well. However, last night I noticed some smoke coming out the intake (the piece in front of the air filter) after turning the car off. Also a few drops of coolant on the garage floor passenger side of the car. Car is not overheating. Is this likely to be coming from inside the engine or burning on the outside somewhere? Link to comment Share on other sites More sharing options...
Carmania24 Posted February 18, 2019 Share Posted February 18, 2019 Maybe excess coolant burning off? Link to comment Share on other sites More sharing options...
EatingInternet Posted February 18, 2019 Share Posted February 18, 2019 What was the color and smell of the smoke. Approximately where in the engine bay was the leak below? Link to comment Share on other sites More sharing options...
DoDo1975 Posted February 18, 2019 Author Share Posted February 18, 2019 It was white, smelled a little like coolant. The drip is on passenger side, below cylinder 2, but its likely dripping off the plastic skid plate or whatever the shroud is called Link to comment Share on other sites More sharing options...
Max Capacity Posted February 18, 2019 Share Posted February 18, 2019 The passenger side is where cylinders 1 and 3 are, the drivers side is where 2 and 4 are. I wonder if the top of the radiator is cracked ? The tank is plastic and these have been known to crack after the car is worked on. If someone leaned on the tank... but there's no way to prove that. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DoDo1975 Posted February 19, 2019 Author Share Posted February 19, 2019 apologies. Then it would be under cylinder 1. Link to comment Share on other sites More sharing options...
DaveWaters Posted February 19, 2019 Share Posted February 19, 2019 Have you taken off the snorkel to inspect the coolant hoses underneath? The drain petcock is on that side as well. Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted February 19, 2019 Share Posted February 19, 2019 Check for any pinhole leaks, it could then spray on a manifold. I had that situation last year and it took me forever find it in the upper rad hose. To do it to have the holes appear like that it pretty much has to be hot enough to get the thermostat to open. 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
DoDo1975 Posted February 19, 2019 Author Share Posted February 19, 2019 Have you taken off the snorkel to inspect the coolant hoses underneath? The drain petcock is on that side as well. I took off the snorkel and looked at the hoses. Couldn't see anything that would cause a leak but there is definitely coolant leaked around there. What is a drain petcock? Link to comment Share on other sites More sharing options...
apexi Posted February 19, 2019 Share Posted February 19, 2019 That's just where you drain the coolant out of the radiator from https://www.subaruoutback.org/forums/attachments/problems-maintenance/17535d1286216624-circulating-tank-heater-rad-drain-medium-.jpg Image above stolen from this thread https://www.subaruoutback.org/forums/66-problems-maintenance/27609-circulating-tank-heater-3.html Link to comment Share on other sites More sharing options...
Max Capacity Posted February 19, 2019 Share Posted February 19, 2019 The coolant lines to/from the turbo run over top of #1 cylinder. Is the leak coming from those hoses ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DoDo1975 Posted February 20, 2019 Author Share Posted February 20, 2019 I found the problem. Small crack in the radiator. Link to comment Share on other sites More sharing options...
EatingInternet Posted February 20, 2019 Share Posted February 20, 2019 Case closed! Nice job, I just had to replace my radiator myself. There's a TYC one on Amazon for $80 after tax prime shipping with great reviews. Says it doesn't fit our cars but it's the same part number that rockauto says is a direct replacement, and mine fit fine. TYC 2778 Subaru 1-Row Plastic Aluminum Replacement Radiator https://www.amazon.com/dp/B000IYR5LK/ Link to comment Share on other sites More sharing options...
