What Did You Do To Your 6th Gen Today Thread - Vol 3
  • 3 weeks later...
Those are going to really pop on ur car looks great
HPS intake, Nameless Axleback Exhaust, SSD FSB, Cusco RSB, 20mm rear sway bar, Voxx 18” rims, Infinity Kappa system,
More to come...
Nice dude it’s coming together
More to come...
Well I found out my air suspension, when at 0psi was dropping the CV joint on the sway bar.
Yikes. It also bent the link pin collar.
I got it all fixed, now the car actually bags out completely at the front and is maybe 20mm lower. Victory!
But now I have major air leakage overnight. Say 40-50psi in each bag and the tank completely empty. FUN!
I also changed the fogs to white LED's, turns out it doesn't need a resistor. Nice. Very bright.
Edited by Libertarian
Well glad you fixed the first issue.. Maybe check your fittings on the bags to make sure there tight. After 80k miles my Front Air Struts need a rebuild..
Sent from my SM-G988U using Tapatalk
Hoping someone here has a thought about what is wrong. '17 OB 3.6R. Battery died completely. Had to do the window reset thing, but my 'combination meter' in the center of my dash also went out. I've tried the basics - pressing and holding the info/set button on the steering wheel, but no luck. The MPG slide gauge at the very top is still there, but the section that can change from compass to MGP, etc, is gone. Thoughts? TIA
Picked up my Wheels from my local Detailing shop today now the waiting game is on for the announcement of the next Car Show so I can install them.. Covid keepin us Down this but not out of the game. cbbe20501eb3281976da691831db8e39.jpg1593d60953ea5cb2c9c09db7e3a6cbc5.jpg81a79f3b46e8c9bf342f849b96a106ff.jpg
Those rims came out amazing
More to come...
If anyone needs a discount on RockAuto.com this code is good through
June 14,2020 for being a rock auto customer for 6 years lol. Should be longer but lost my old email address. Cheers!
135589831103902331
Follow me on IG @chefodiycarguy
and @chefo.soriano
What size are those im about to pull the trigger on a set of Work emitz 19x9.5 i want my fitment perfect tho
Are you going to put Air or Springs? Mine are 19 x 8.5 +41 because I have a big brake kit up front and Air I want my Wheels ro Tuck Fender. You might be able to go with Medium Disk or Low Disk and go +38. 9.5 Might be too much 9" would be better.
I have BC Racing BR Series maxed out all around
But this guy in japan fit them but he has air bags too so i dont know? http:// https://twitter.com/yo1289bbkg/status/1254235850457485314?s=21
http:// https://twitter.com/yo1289bbkg/status/1253989101629366278?s=21
Edited by darrien917
This is my friend in Japan on 20 x 9 +38 in the Rear and +41 in the Front.. I can't remember what disc size he has though.f6d0bed52de6e02b1aec870cdae343f5.jpg
Oi, i follow him!
pulled the trigger. you only live once, right?
I might need adjustable lower control arms tho.
any links?
Oi, i follow him!
any links?
That "A" Disk might not clear.. Did you talk with the people you ordered them from? If they were a good shop and knew Wheels they should of been able to give u some good recommendations. So what offset did you get?
You can get Cusco Lower Control Arms look under BRZ or WRX Models... Stay away from ISC there quality is not good and have a tendency to break.
Edited by Grnlantern1
Wait a minute... All BRZ rear lower control arms fit the BN9?
Yes.. The Rear Suspension of the BN Series is the same from a 2010 and Newer Legacy, WRX/Sti and BRZ. So either BRZ Arms or WRX Lower Arms should fit.
