Surfcast23 Posted April 16, 2019 Share Posted April 16, 2019 Hello All, My headlights are so dim that my fog lights are brighter. I thought it may have been the bulbs so I switched both and the problem persists. I also noticed that my DTRL don't work at all after reading through other posts from people with similar issues. I am no good at electrical and would like to ask for any pointers. Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted April 16, 2019 Share Posted April 16, 2019 First check all your grounds, over time they corrode and can cause this and many other voltage issues 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
Surfcast23 Posted April 16, 2019 Author Share Posted April 16, 2019 First check all your grounds, over time they corrode and can cause this and many other voltage issues Will do tomorrow, at work now. Link to comment Share on other sites More sharing options...
apexi Posted April 17, 2019 Share Posted April 17, 2019 both headlights being dim makes me think maybe this isn't the problem, but it's worth a shot. I'd check the headlight fuses 6 and 7 in the engine bay. In the past there have been problems where people have had one dim headlight, and one normal brightness. The dimmer one had a blown fuse, and was somehow still pulling power from somewhere. Link to comment Share on other sites More sharing options...
Surfcast23 Posted April 19, 2019 Author Share Posted April 19, 2019 First check all your grounds, over time they corrode and can cause this and many other voltage issues Cleaned contacts, no change. both headlights being dim makes me think maybe this isn't the problem, but it's worth a shot. I'd check the headlight fuses 6 and 7 in the engine bay. In the past there have been problems where people have had one dim headlight, and one normal brightness. The dimmer one had a blown fuse, and was somehow still pulling power from somewhere. Fuses are good Link to comment Share on other sites More sharing options...
apexi Posted April 20, 2019 Share Posted April 20, 2019 I'm thinkin it's something with the drl control module, or power going to that since both headlights are affected the same way. It looks like one of the other relays in the box should work where the DRL relay goes, I'd try swapping relays to see if it fixes it. It looks like fuse #18 might give power to the drl relay, if haven't checked that one yet. drl control module has a msrp of $65, not too bad, but I wouldn't go for one of those yet. I can't find any instructions in the fsm for troubleshooting the drl control module. Link to comment Share on other sites More sharing options...
Surfcast23 Posted April 20, 2019 Author Share Posted April 20, 2019 I'm thinkin it's something with the drl control module, or power going to that since both headlights are affected the same way. It looks like one of the other relays in the box should work where the DRL relay goes, I'd try swapping relays to see if it fixes it. It looks like fuse #18 might give power to the drl relay, if haven't checked that one yet. drl control module has a msrp of $65, not too bad, but I wouldn't go for one of those yet. I can't find any instructions in the fsm for troubleshooting the drl control module. Checked fuse 18 yesterday and its good, I'll check the relays when it stops raining. Thanks for the suggestion. Link to comment Share on other sites More sharing options...
DaveWaters Posted April 20, 2019 Share Posted April 20, 2019 You can unplug the drl module to rule it out. Your headlights will operate like normal just no drl. The info is in the cheap and or free mods sticky at the top of the forum. Link to comment Share on other sites More sharing options...
Surfcast23 Posted April 20, 2019 Author Share Posted April 20, 2019 You can unplug the drl module to rule it out. Your headlights will operate like normal just no drl. The info is in the cheap and or free mods sticky at the top of the forum. The DRL's are not working at all as well as the headlights being extremely dim. Link to comment Share on other sites More sharing options...
DaveWaters Posted April 20, 2019 Share Posted April 20, 2019 The DRL's are not working at all as well as the headlights being extremely dim. Right.. but if the module isn’t causing a problem in the circuit, by unplugging it you can rule it out. If you unplug it and get your headlights back you know its bad. If you unplug it and there’s no difference then back to diagnostics and no need to replace drl module. Link to comment Share on other sites More sharing options...
Surfcast23 Posted April 20, 2019 Author Share Posted April 20, 2019 Right.. but if the module isn’t causing a problem in the circuit, by unplugging it you can rule it out. If you unplug it and get your headlights back you know its bad. If you unplug it and there’s no difference then back to diagnostics and no need to replace drl module. Gotcha! Link to comment Share on other sites More sharing options...
Surfcast23 Posted April 23, 2019 Author Share Posted April 23, 2019 Just swaped the DRL and fog light relays with no change. Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted April 23, 2019 Share Posted April 23, 2019 try pulling the connector to the headlight and with a multimeter see what the voltage is, might give us a few more clues 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
Surfcast23 Posted June 10, 2019 Author Share Posted June 10, 2019 try pulling the connector to the headlight and with a multimeter see what the voltage is, might give us a few more clues Finally got a change to check the voltage and its 11.92V. Link to comment Share on other sites More sharing options...
JmP6889928 Posted June 10, 2019 Share Posted June 10, 2019 DRL box could be holding back voltage if it's failed inside. Make sure and unplug it Link to comment Share on other sites More sharing options...
boxkita Posted June 10, 2019 Share Posted June 10, 2019 check the grounds all around. If they are factory, they are toast by now. My welding cables got replaced with factory copies and car barely runs. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Surfcast23 Posted June 10, 2019 Author Share Posted June 10, 2019 DRL box could be holding back voltage if it's failed inside. Make sure and unplug it Where is the box located? I also don't think a 0.08 drop in voltage make that much of a difference? Link to comment Share on other sites More sharing options...
