doublechaz Posted February 10, 2018 Share Posted February 10, 2018 My new water pump came with a thin stamped metal gasket. I'm accustomed to using a paper gasket and RTV. Does anyone in the Subaru Tech position have advice on this? Does the metal gasket still use RTV? Should I go with paper and RTV? Skip it and just RTV? I don't want to get in here and do this job again to fix a leak. Thanks. Link to comment Share on other sites More sharing options...
Osei Posted February 10, 2018 Share Posted February 10, 2018 No RTV just the gasket. Although I have used a little to hold in in place at times. Never use the paper gaskets. O. Link to comment Share on other sites More sharing options...
Brighton96 Posted February 10, 2018 Share Posted February 10, 2018 Depending on the motor, I think the gaskets are either thin metal or rubber, do not use RTV at all, the only things that should be RTV'd from the factory are the oil pan and oil pump. The waterpump install also specifies a cross/star torque pattern and they do require a specific torque spec Link to comment Share on other sites More sharing options...
Setnev Posted February 10, 2018 Share Posted February 10, 2018 No RTV unless you want to be doing it again because it's leaking. You can, like O said, use a little to help hold the gasket in place. All of my water pumps came with a paper gasket, and I actually might have another one lying around somewhere. Link to comment Share on other sites More sharing options...
doublechaz Posted February 10, 2018 Author Share Posted February 10, 2018 Good info, thanks. Link to comment Share on other sites More sharing options...
