samuel082799 Posted January 23, 2020 Share Posted January 23, 2020 I have already purchased all the components to make my oil feed supply come from a sandwich plate on the oil filter. Doing some extra research i found that people are saying that this setup is overkill and not needed with a stock turbo. Right now I am building a long block for my car and i have already rebuilt a vf40 turbo that will be going on the car. All of my banjo bolt filters have been removed and I have had no problems with the stock oil feed system. In probably a year's time, I will be upgrading my turbo to a BCP x400 or x500. I know that I will be able to run the stock turbo on stock lines without a problem. My question is does the bigger turbo need a more efficient oil feed system than stock can provide, and if so would i see any detrimental affects running the upgraded oil feed on the stock turbo to make the turbo swap easier in the future, and since i already have the stuff. I have also heard concerns of over oiling which doesn't make much sense to me, because it seems like with a journal bearing turbo you would want as much oil flow as possible to keep clean cool oil between the bearings. Is this over oiling a valid concern? Link to comment Share on other sites More sharing options...
Max Capacity Posted January 23, 2020 Share Posted January 23, 2020 (edited) The vf40 has a orifice in the banjo bolt at the turbo. The new turbo may have the same basic set, but may have a larger hole in the orifice. Contact the manufacture or shop your buying from and ask them. Years ago in the race car as well as a friends car I put a pressure gauge in the supply line and a shut off valve before the turbo. When a got the correct oil flow by adjusting the shut off valve. I removed the handle so you could not move the shut off valve. Here's one of the editions of the set up, Here's an idea of shut off valves. https://www.bing.com/shop?q=shut+off+valve&FORM=SHOPTB Edited January 23, 2020 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
samuel082799 Posted January 23, 2020 Author Share Posted January 23, 2020 So is that valve used as a way to regulate ho much oil is going into the turbo? Is the gauge before or after the valve, and is there a certain oil pressure that is specified for different turbos? Link to comment Share on other sites More sharing options...
Max Capacity Posted January 23, 2020 Share Posted January 23, 2020 Yes, the shut off just metering valve at that point. The gauge was after the shut off valve. Once I found the spot, (it was easy), I removed the gauge set up. The friends street Integra I left the gauge on and he drove it for many years. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
samuel082799 Posted January 24, 2020 Author Share Posted January 24, 2020 Yes, the shut off just metering valve at that point. The gauge was after the shut off valve. Once I found the spot, (it was easy), I removed the gauge set up. The friends street Integra I left the gauge on and he drove it for many years. What are you supposed to be looking for when dialing in your oil pressure? In other words how do I know what oil pressure to set it to? Link to comment Share on other sites More sharing options...
