Dbaucco Posted March 24, 2019 Share Posted March 24, 2019 Hi there folks! New to this forum but I've been working on and rebuilding cars for 15 yrs or so. I now have several Subarus, all Legacy,01,04 and 09. I've got some new slotted and drilled front rotors for the 09 but I'm looking for an inexpensive front caliper upgrade using the stock wheels and tires. Any ideas? Thanks in advance! Dan Link to comment Share on other sites More sharing options...
Navy Goat Posted March 24, 2019 Share Posted March 24, 2019 I would be interested in the same thing, although I suspect there is no such thing as an inexpensive caliper upgrade. I wonder if anyone has tried the rebuilt OEM calipers available from PowerStop? Click on the Caliper option at the link below. https://www.powerstop.com/products/#y=2009&mk=SUBARU&mo=LEGACY&ss=2.5GT%2C%20Spec%20B%2C%203.0R%20Limited&p=Front%20%26%20Rear Link to comment Share on other sites More sharing options...
chato Posted March 24, 2019 Share Posted March 24, 2019 you don’t clarify whether you have a GT or not. the GT has the largest subaru brakes short of brembos. bang for buck you’re going to get the best improvement in both performance and feel from from high quality pads, MC brace and SS lines. if you have a 2.5i upgrading to the GT brakes would be an inexpensive way to get a lot more braking power. Link to comment Share on other sites More sharing options...
gary.congleton Posted March 25, 2019 Share Posted March 25, 2019 Best thing to start with. Tires. Tires are the most important thing to stop your car. Them after that hawk pads and dba blank rotors Sent from my SM-N950U using Tapatalk Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 25, 2019 Share Posted March 25, 2019 Akebono ceramics. They're not expensive, they don't dust very much, quiet, and they stop fine. I have them on mine with Centric cryo blanks and they work great. I also run the Motul 600 fluid with SS hoses and Ti shims. I don't know if I would run the pads on the track as I think you would be sorely lacking at high speeds. Link to comment Share on other sites More sharing options...
Dbaucco Posted March 25, 2019 Author Share Posted March 25, 2019 Sorry,none of my cars are GT. Just base model Legacy. Link to comment Share on other sites More sharing options...
l88m22vette Posted March 26, 2019 Share Posted March 26, 2019 Spec B is an upgrade over the regular and GT brakes, the calipers are better but allow the use of larger rotors (and the rears let you use vented instead of solid rear disc). I'd also invest in a Grimmspeed master cyl brace, I was skeptical but it really makes a huge difference. Link to comment Share on other sites More sharing options...
nevets27 Posted March 26, 2019 Share Posted March 26, 2019 (edited) Spec B is an upgrade over the regular and GT brakes, the calipers are better but allow the use of larger rotors (and the rears let you use vented instead of solid rear disc). I'd also invest in a Grimmspeed master cyl brace, I was skeptical but it really makes a huge difference.Pretty sure this isn't true the GT, the spec b and the 3.0R Limited all have the same brakes in USDM. The base 2 5i has smaller front rotors and none vented but same size rotors in the rear. The 3.0R in Canada got the same brakes as the 2.5i. To answer the OP, upgrading the front rotors and calipers to the GT version will give you bigger/better front brakes. This is what I will likely do in the future. I'm not going to bother doing the rears in the short term due to it not really having any effect on better braking. You really only need vented to cool the brakes quicker and unless you are driving it hard with lot of braking/track days etc. Then you won't heat up the rears enough to need vented. The rest in the rear is equal so it won't gain anything in the rear for better braking. Edited March 26, 2019 by nevets27 Link to comment Share on other sites More sharing options...
seanyb505 Posted March 26, 2019 Share Posted March 26, 2019 Best thing to start with. Tires. Tires are the most important thing to stop your car. Them after that hawk pads and dba blank rotors Sent from my SM-N950U using Tapatalk This times one billion. Are the brakes on the non-GT that bad? I've always told myself "If you can activate ABS, you don't need new brakes you need better tires." Putting on grabbier brake materials on the same tires will lock up your tires faster. Brakes stop the wheel from spinning, tires are what translate that friction to the road surface. Your car has a lot of pounds that want to keep going where they're heading at the rate they're heading there, and not slow down so abruptly. If it's pedal feel you're after, I'd start with a fluid flush. I've always had seat of the pants enjoyment after flushing fluid. There are other components after that, but there are a few before you get to a different caliper. I know you said stock wheels and tires, but you will not increase stopping distance without changing tires. I can't remember exactly who it was, but someone on here was tracking their GT with stock calipers. I know brake bling is quite blingy, as I really want the look of brembos. Lately I've gotten even more excited when I see a set of Pilot Super Sports or PS4S tires. Link to comment Share on other sites More sharing options...
kzr750r1 Posted March 26, 2019 Share Posted March 26, 2019 I just pulled the trigger on a LGT upgrade from my OBXT. Looking forward to this. Go to Rock Auto and start digging into how much you want to spend. Way cheaper buying reman than new stuff. I went will all Raybestos except for the rear calipers and Cryo treated vented rotors, no fancy holes or slots needed for a daily. Link to comment Share on other sites More sharing options...
Notorious Posted March 26, 2019 Share Posted March 26, 2019 Spec B is an upgrade over the regular and GT brakes, the calipers are better but allow the use of larger rotors (and the rears let you use vented instead of solid rear disc). I'd also invest in a Grimmspeed master cyl brace, I was skeptical but it really makes a huge difference. All Spec B’s have the same brakes as the LGT, which like mentioned earlier is the largest caliper Subaru makes short of the STI Brembos. Link to comment Share on other sites More sharing options...
kzr750r1 Posted March 26, 2019 Share Posted March 26, 2019 Besacktly why I went this direction. Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 26, 2019 Share Posted March 26, 2019 I track my LGT with OE front and rear calipers, Ti shims, Hawk pads, and Centric Cryo blanks. I use either the Wilwood 600 or Motul 600 fluid and freshly flush all fluid before going to the track. I never have fade and they work fine. Link to comment Share on other sites More sharing options...
Notorious Posted March 26, 2019 Share Posted March 26, 2019 I track my LGT with OE front and rear calipers, Ti shims, Hawk pads, and Centric Cryo blanks. I use either the Wilwood 600 or Motul 600 fluid and freshly flush all fluid before going to the track. I never have fade and they work fine. Which hawk pads do you use for track? Curious. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 26, 2019 Share Posted March 26, 2019 Spec B is an upgrade over the regular and GT brakes, the calipers are better but allow the use of larger rotors (and the rears let you use vented instead of solid rear disc). I'd also invest in a Grimmspeed master cyl brace, I was skeptical but it really makes a huge difference. Not true. I have swapped brake parts onto both my cars. No difference 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 26, 2019 Share Posted March 26, 2019 Hp+. Not hard on the rotors, stop great, but do leave a lot of black dust and they're only really good for 2 track days (8-12-solid 20 minute sessions) at best. Once they're down past halfway, I don't use them again as I don't want the heat transfer to the calipers. Even with Ti shims, they can still push a lot of heat into the pistons. Link to comment Share on other sites More sharing options...
bemani Posted March 27, 2019 Share Posted March 27, 2019 Hi there folks! New to this forum but I've been working on and rebuilding cars for 15 yrs or so. I now have several Subarus, all Legacy,01,04 and 09. I've got some new slotted and drilled front rotors for the 09 but I'm looking for an inexpensive front caliper upgrade using the stock wheels and tires. Any ideas? Thanks in advance! Dan My WRX uses LGT brakes (makes buying parts so much easier since I don't have to remember which is for which car) and on the lighter car the LGT brakes is already a very big improvement. You should look into upgrading your other 2 cars too Link to comment Share on other sites More sharing options...
kzr750r1 Posted March 27, 2019 Share Posted March 27, 2019 (edited) Just received most of my order. These GT rotors and calipers are massive in comparison to the OBXT setup. Nice to see the rears are vented as well AGAIN massive by comparison. Edited March 27, 2019 by kzr750r1 Link to comment Share on other sites More sharing options...
whitexc Posted March 27, 2019 Share Posted March 27, 2019 Just received most of my order. These GT rotors and calipers are massive in comparison to the OBXT setup. Nice to see the rears are vented as well AGAIN massive by comparison.Where did you get parts from ? Sent from my moto z3 using Tapatalk Link to comment Share on other sites More sharing options...
kzr750r1 Posted March 28, 2019 Share Posted March 28, 2019 Rock Auto. More than just brakes here but you get the idea. 2006 SUBARU OUTBACK 2.5L H4 Turbocharged KYB 339099 Strut $ 65.89 $ 0.00 1 $ 65.89 KYB 339098 Strut $ 66.79 $ 0.00 1 $ 66.79 MOOG K90329 Strut Mount $ 19.67 $ 0.00 2 $ 39.34 RAYBESTOS BH381352 Hydraulic Hose $ 17.83 $ 0.00 1 $ 17.83 RAYBESTOS BH381350 Hydraulic Hose $ 17.83 $ 0.00 1 $ 17.83 RAYBESTOS BH382649 Hydraulic Hose $ 9.01 $ 0.00 1 $ 9.01 RAYBESTOS BH382648 Hydraulic Hose $ 8.87 $ 0.00 1 $ 8.87 RAYBESTOS BH382650 Hydraulic Hose $ 6.88 $ 0.00 1 $ 6.88 2006 SUBARU LEGACY 2.5L H4 Turbocharged CARDONE 19B3105 (19-B3105) Caliper $ 43.79 $ 70.00 1 $ 113.79 CARDONE 19B3104 (19-B3104) Caliper $ 43.79 $ 70.00 1 $ 113.79 RAYBESTOS FRC11848C Caliper $ 45.99 $ 90.00 1 $ 135.99 RAYBESTOS 980347 Rotor $ 48.79 $ 0.00 2 $ 97.58 RAYBESTOS 980361 Rotor $ 54.79 $ 0.00 2 $ 109.58 RAYBESTOS FRC11847C Caliper $ 45.99 $ 90.00 1 $ 135.99 RAYBESTOS EHT770H Brake Pad $ 20.79 $ 0.00 1 $ 20.79 RAYBESTOS EHT1078H Brake Pad $ 35.79 $ 0.00 1 $ 35.79 2004 SUBARU OUTBACK 2.5L H4 KYB 341276 Strut $ 56.79 $ 0.00 2 $ 113.58 Shipping Ground $ 56.94 Order Total $ 1166.26 Link to comment Share on other sites More sharing options...
whitexc Posted March 28, 2019 Share Posted March 28, 2019 You should not have to pay for shipping when spending over $1k...my opinion. Thanks for the list. Link to comment Share on other sites More sharing options...
kzr750r1 Posted March 29, 2019 Share Posted March 29, 2019 Still cheaper than any of the other distributor options I investigated. Link to comment Share on other sites More sharing options...
whitexc Posted March 29, 2019 Share Posted March 29, 2019 Oh I hear yah bud. I get parts from RA, just thinking out loud I was! Sent from my moto z3 using Tapatalk Link to comment Share on other sites More sharing options...
KRYPTO Posted March 29, 2019 Share Posted March 29, 2019 How about the sti booster and master swap? Link to comment Share on other sites More sharing options...
kzr750r1 Posted March 30, 2019 Share Posted March 30, 2019 (edited) What is the difference between the two? Never really looked at that part, or the bias plumbing for that matter. Edited March 30, 2019 by kzr750r1 Link to comment Share on other sites More sharing options...
