horrible shuddering idle
Car starts fine
Drives well
Shifts ok
No cel
However, at idle the car acts like its going to stall (occasionally does)
Just started yesterday. Going to upload a video of the shuddering idle to youtube. Will post link/try to embed here afterwards.
Seems like vacuum related, not sure.
Any ideas?
Thanks
My car is doing the same thing. RPM's at idle just drop sometimes. It stopped for awhile & I spaced it, but it just started again. Seems to be some what common but a lot of different possibilities. Keep us updated
Did you clean the MAF sensor with the $8.00 can of MAF sensor cleaner first.
Then did you spray Carb Cleaner around the intake manifold to TGV's to see if the thin OEM o-rings are leaking ? that is the normal fix for these cars, when you see the new o-rings next to the old ones you'll understand. The o-rings are $20.00
There are a ton of threads about this issue.
Oh Yea, If you buy a front O2 make sure it's a OEM one, that's seems to be what recommended here.
Engine Build - Click Here
Have you had any luck with this stuff?
I always use seafoam every oil change. But I've only used it through the gas tank. That method hasn't' fixed this problem for me. I attribute seafoam for helping keep my 93 Impreza running as long and well as it does though.
Excuse the noob question... the hell is a tgv?
According with the service manual this are the possible causes:
in order :
- Electronic throttle control
-manifold absolute pressure sensor
-mass air flow and intake air temperature sensor
-Engine coolant temperature sensor ( only in low temperatures)
-Ignition parts (Ignition coil and spark plugs)
-Air intake system (air leaks in the intake system)
-Fuel injection parts (check fuel injectors, fuel pressure regulator and fuel filter)
-Crank shaft position sensor (ensure secure installation)
-Camshaft position sensor ( ensure secure installation)
- Oxygen sensor
- Fuel pump and fuel pump relay
I had the same exact problem
I removed the white plastic pice with the foam around just put a hose between the manifold and the map sensor which is where that is located on the same bracket as the boost controller
I was under the impression that that pice was a "check valve" it isn't its a inline filter to keep oil and debris from entering the map sensor as its after pcv system, as soon as my local subaru dealer figures out what it is ill order a new one but I broke mine apart to find out exactly what it was so that's why I just put a straight tube in place of it. After inspecting the pice I found two sandwiched pieces of filter element that were dirty with oil which was not allowing the map sensor to get a accurate reading under vacuum which causes the hesitation and stalling when not on the throttle.
