thefaidley Posted September 21, 2019 Share Posted September 21, 2019 (edited) DOes anyone have pictures of where all the lines should be hooked up the online diagram dont help i have a 05 legacy 2.5gt At turbo had motor replaced and none of line looked up and missing some Edited September 21, 2019 by thefaidley Link to comment Share on other sites More sharing options...
Max Capacity Posted September 21, 2019 Share Posted September 21, 2019 Check the sticky's at the top of the forums. or heres the service manual, http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted September 21, 2019 Share Posted September 21, 2019 Sorry, I thought there was a sticky for them. may be try a google search for them https://www.google.com/search?source=hp&ei=xXOGXeHmCMmJ5wKOur7gBw&q=vacuum+line+routing+2005+subaru+legacy+GT&oq=vacuum+line+routing+2005+subaru+legacy+GT&gs_l=psy-ab.3..33i22i29i30l4.2578.23430..23985...6.0..0.253.4790.27j20j1......0....1..gws-wiz.....9..0i143j0i131j0j0i22i30j33i299.5b0a9DzeAiw&ved=0ahUKEwih3YugzeLkAhXJxFkKHQ6dD3wQ4dUDCAg&uact=5 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
awfulwaffle Posted September 21, 2019 Share Posted September 21, 2019 (edited) Max, it's buried in JMP's ideas sticky somewhere. We should really index that. Use post 15 in this thread. https://legacygt.com/forums/showthread.php/2005-2006-lgt-colored-vacuum-routing-diagram-143225.html The diagram shows a 3-port boost control solenoid. If you're still using the original 2-port one, one port will still connect to the turbo inlet, and the other port will connect to the "tee" in the line which runs between the two ports on the turbo itself. Edited September 21, 2019 by awfulwaffle Link to comment Share on other sites More sharing options...
