burtman Posted September 16, 2019 Share Posted September 16, 2019 My daughter purchased used Bean OB (2001 Outback/L.L. Bean; 3.0 Engine, 4EAT transmission) in April, 2019 with ~ 147K miles. AT Oil Temp light issues (see below) started @ ~ 154,500. I’m am fairly experienced with working on cars, but this is my first Subaru. Experience with transmissions is limited to basic maintenance/service. Overall the OB looks to be in pretty good shape – engine runs great, ride is solid, etc. I’m now debating whether to try and fix the OB or just cut my losses and consider buying my daughter another vehicle. I have extensively researched the” AT Oil Temp light flashing” issue online, and would GREATLY appreciate any advice offered on what my best options are…fix the OB or get rid of it and cut my losses? And for all you fathers with daughters out there, this is a classic “rescue daddy” situation. I would much prefer to fix the OB if possible as this is my daughter’s first experience buying a car on her own. I’d like for it to not be seen as a tragedy by her (just maybe with a lesson learned that asking dear ol’ Dad for help early is a good thing). Current Symptoms AT Oil Temp light flashing Code 79 (Transfer duty solenoid) with OB going into AWD mode (torque bind, etc.) as soon as AT Oil Temp light starts flashing. AT Oil Temp light flashes and goes into AWD mode whether in normal or 2WD drive mode (fuse inserted)BUT…the OB will go much longer/farther in 2wd mode (fuse in) before symptoms arise than in normal mode (fuse out)Definitely temperature related more than miles driven - AT Oil Temp light never flashes in cool weather or when driving through rain. And AT Oil Temp light stops flashing once car is cooled down, only to arise again after being driven in hot weather, stop & go, etc..Also…Check engine light recently came on with code indicating misfire on cylinders 2 & 4. I believe this in unrelated but wanted to mention just in case. Probably just needs new plugs? Maintenance performed (so far) Completed 3 drain/refills on trans fluid, with new trans filter installed on 3rd drain/refill. This seemed to offer some improvement in that OB now goes further/longer before AT Oil Temp light flashes and AWD mode kicks in.1st drain refill indicated that trans fluid had likely never been changed/serviced. VERY dark brown (nasty stuff). Also completed 2 drain/refills on rear differential and 1 drain/refill on front differential. No noticeable improvement noted. Condition of drained differential fluid reasonable, with no noticeable contaminants or metal shavings present (I’ve seen much worse). I went to a highly recommended local (Atlanta GA) independent Subaru shop and was told that if AT Oil Temp light flashes and AWD symptoms arise in 2WD, problems are deep within transmission and the only fix is to replace transmission at minimum of ~$2,500. I was about ready to write the OB off at that point, but after looking into issue a bit further online, I question whether this is truly my only remaining option. Based on what I have been able to find, it looks like a DIY project to replace the transfer duty solenoid & clutch plates will very likely resolve the issue and get the OB back on the road again. Is there anything else I missed that I should consider as possible solution/fix? If not, is it worth the effort to try replacing the transfer duty solenoid myself (along with clutch plates)? I’ve looked online, and I believe this is something well within my capability. But it is a helluva project, and I don’t want to do it unless there is at least a reasonable chance of success. The best link I found for transfer duty solenoid replacement is at https://forums.nasioc.com/forums/showthread.php?t=2501432. Any advice, suggestions, references, links, etc. are much appreciated. Finally, before considering replacing the transfer duty solenoid myself, I thought I’d do one more drain/refill of trans fluid and add BG ATC additive to see if this helps. Sound reasonable? The over-riding question to all you Subaru enthusiasts out there is, “What would you do if you were me?” Thank you so much in advance for any assistance offered. My first post here (great website)…hope it is OK. Link to comment Share on other sites More sharing options...
RumbleRumble Posted September 16, 2019 Share Posted September 16, 2019 put the FWD fuse will ensure the wiring is fine, if not I'd try and replace the duty solenoid. It's mounted on the rear of the case. Link to comment Share on other sites More sharing options...
doublechaz Posted September 17, 2019 Share Posted September 17, 2019 ATs aren't really my area, but you mention there is a real trans heat problem. Does it have four of the same brand and model tires with the same age/tread depth? You can't mix and match at all if the 2WD fuse has an electrical problem. If it goes AWD with mismatched tires it would make a lot of heat in the trans. Link to comment Share on other sites More sharing options...
burtman Posted September 18, 2019 Author Share Posted September 18, 2019 "put the FWD fuse will ensure the wiring is fine, if not I'd try and replace the duty solenoid. It's mounted on the rear of the case." This makes absolutely no sense...did you even read my post? And tires are fine...not the issue. Link to comment Share on other sites More sharing options...
doublechaz Posted September 18, 2019 Share Posted September 18, 2019 Good news on the tires. Do you have a Factory Service Manual for your year? There is probably a short list of simple tests to narrow down what's wrong. I would think that one test would be to disconnect the harness and apply ground to pin X and 12v to pin Y and listen for the click of the solenoid. But without the FSM you won't know which pins to use. Choosing wrong might even let out the magic smoke. Link to comment Share on other sites More sharing options...
burtman Posted September 21, 2019 Author Share Posted September 21, 2019 After carefully studying the FSM A/T Control System schematic, digging a bit deeper into the harness setup, I walked through the troubleshooting diagnostics again: Step1 – Check transfer duty solenoid PASSED @ 12.6 ohms; within req’d 10-17 ohmAlso checked at B54 conn @ TCM (#15 - #16 (ground) and got almost exactly the same resistance Step 2 – Check harness between TCM & Transmission PASSED @ 0.2 ohms; less than required 1 ohm Step 3 – Check harness conn between TCM & transmission Passed @ OL; greater than req’d 1 Mega-ohm Step 4,5 – Check TCM output signal in “P” PASSED @ 0.139V; less than req’d 1VNote: For steps 4,5,6 - I measured voltage from back side of B54 connector @ #15 while plugged into TCM. Step 6 - Check TCM output signal in “D” FAILED @ 4.05V; less than req’d 5V to 7V range Per FSM,indicates "poor contact” in xfer duty solenoid circuit OR replace TCM Took for OB for a drive. FWD fuse out. AT Oil Temp Light came on. Pulled over to take readings with engine running and warm… Checked at B54 conn @ TCM (#15 -ground); R = 17-20 ohmsChecked at B54 conn @ TCM (#15 - #16); R = 20-24 ohms Seems to me that the above should be much closer to the same values? And both should be within 10 -17 ohm range per FSM? Left engine running, checked voltage @ B54, #15 to ground 12.68 V in "P" (should be < 1V) Any ideas from anyone? Do readings make any sense at all? Do I need to check again? BTW...I have checked to the best of my ability and I do NOT have VDC. Link to comment Share on other sites More sharing options...
doublechaz Posted September 21, 2019 Share Posted September 21, 2019 (edited) If I'm following what you've posted pin #15 @ B54 is the power side of the transfer duty solenoid and pin #16 provides ground to the solenoid. Getting a different value for tests hot vs cold typically means you are on the problem circuit. The ohms mode on a DVM sends a known small voltage between the probes and then measures the current flowing in the probes to determine the resistance. This doesn't always work right testing in circuit if the circuit is getting other power besides what the meter is giving, that is to say the circuit is on. So I hate to send you testing, but the ohms pin #15 and #16 hot with it running are probably not accurate. You would want to do those tests hot and just now turned off. But I think the 12v in park hot when should be less than 1v shows that when hot either the harness is going to open circuit on those pins or else the solenoid is going open circuit internally when hot (burned out). So I would say do the step 1 tests again key off when hot and exhibiting the problem. If it passes then solenoid good and do step 2 which would hopefully be the opposite result of step 1. Edited September 21, 2019 by doublechaz Link to comment Share on other sites More sharing options...
burtman Posted September 21, 2019 Author Share Posted September 21, 2019 OK...I have checked and double-checked readings: When engine is hot and AT Oil Temp Light flashes: Transfer duty solenoid resistance is between 20+ to 24 ohms. NOTE: Resistance readings tends to drop rather fast – I had initial reading in high 20’s up to 30+ (depending on how fast I could get to location with meter). I assume this is due to temperature? TCM output voltage in “P” & “D”” is 11.83V (FAIL per FSM) When engine is hot and AT Oil Temp Light NOT flashing: Transfer duty solenoid resistance is 33 ohms (steady)TCM output voltage in “P” is 0.16V (PASS)TCM output voltage in “D”” is 4.49V, which is very close to the 4.05V initial reading I got with engine cold (FAIL req’d > 5 V min) I attached a PDF of a table I created of the readings…hope it comes through and is helpful. NOTES: Torque bind occurs ONLY when AT Oil Temp Light Flashing Definitely temperature related – symptoms disappear as soon as engine allowed to cool down for as little as ~30 minutes. But come back quickly unless engine allowed to cool completelyShifting between gears seems a bit “hard” (with no light flashing / torque bind). This may normal for a Subaru (seems like I read that somewhere) but though it worth mentioning.OB does NOT have VDC QUESTIONS: I thought it interesting that whenever AT OIL TEMP light flashin, there is a direct correlation to high output V readings @ TCM. Per doublechaz above, look like the solenoid is going open circuit internally when hot (burned out) and needs replacing? If any other readings or checks are desired, just say the word….I’ll jump right on it. Would taking readings with FWD fuse in be helpful? I am so ready to get past this...Subaru Readings.pdf Link to comment Share on other sites More sharing options...
