B1G_xyz Posted January 20, 2021 Share Posted January 20, 2021 Hey guys just got new tires, michelin pilot sport all season 4, squared on enkei 18x8 +45. They are rubbing when I hit bumps and I wanted to know what is recommended; camber? Coilovers? Fender rolling? Thanks Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
Pleides Posted January 20, 2021 Share Posted January 20, 2021 Fender rolling should cover that on stock suspension. I'll be putting that on my car with H&R lowering springs (those exact specs actually) and it supposedly shouldn't rub with rolled fenders. Link to comment Share on other sites More sharing options...
B1G_xyz Posted January 20, 2021 Author Share Posted January 20, 2021 Fender rolling should cover that on stock suspension. I'll be putting that on my car with H&R lowering springs (those exact specs actually) and it supposedly shouldn't rub with rolled fenders.Awesome, thanks going to look for some place to roll them now! Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
B1G_xyz Posted January 21, 2021 Author Share Posted January 21, 2021 This is how much I'm rubbing btw Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
Pleides Posted January 21, 2021 Share Posted January 21, 2021 Looks like you're rubbing on the exact part of the fender that would be rolled back. You'll likely find that you're fine afterwards. Are you rubbing on all four? Adding in a degree of camber would help with rubbing. Link to comment Share on other sites More sharing options...
B1G_xyz Posted January 21, 2021 Author Share Posted January 21, 2021 Looks like you're rubbing on the exact part of the fender that would be rolled back. You'll likely find that you're fine afterwards. Are you rubbing on all four? Adding in a degree of camber would help with rubbing.Yep all four but more severely in the fronts...just ordered a eastwood fender roller and I'm tackling this on Sunday Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
Pleides Posted January 21, 2021 Share Posted January 21, 2021 Good luck. I assume you have a heat gun? Link to comment Share on other sites More sharing options...
B1G_xyz Posted January 22, 2021 Author Share Posted January 22, 2021 Yes I do. Also just realized the bozos at Pep boys but 50psi in each tire. I wonder if that contributed to my rubbing. Link to comment Share on other sites More sharing options...
Pleides Posted January 23, 2021 Share Posted January 23, 2021 May have. Always check your tire pressure as often as you can on our cars as they don't have TPMS Link to comment Share on other sites More sharing options...
B1G_xyz Posted January 24, 2021 Author Share Posted January 24, 2021 Yep, I normally check them once a week with the winter weather causing low pressure Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
