photog Posted January 10, 2011 Share Posted January 10, 2011 Noticed my plate lights were both out a few weeks ago. Since then I've replaced them twice. They had 194s in there, so I first replaced them with new 194s, then read in the manual that they should be 168s. Neither bulb swap worked, and I can't find a blown fuse, which seemed unlikely anyway. Anyone have any ideas as to where to go next? Link to comment Share on other sites More sharing options...
VermontGT Posted January 11, 2011 Share Posted January 11, 2011 Forgive my question, but just to make sure...you have your headlights on when you're checking the license plate lights, right? Link to comment Share on other sites More sharing options...
photog Posted January 11, 2011 Author Share Posted January 11, 2011 Yes. Lights on, car running. Every other light on the exterior works. Link to comment Share on other sites More sharing options...
Drift Motion Posted January 11, 2011 Share Posted January 11, 2011 194 and 168 are interchangeable and if your using LED, they have a polarity, only one way works Link to comment Share on other sites More sharing options...
Instanced Posted January 12, 2011 Share Posted January 12, 2011 are you the original owner of the car? was the trunk door replaced for any reason? Take a multimeter (buy one if you don't already have one) and set it to 20V and test to see if any voltage is getting to the bulb holders (with the car on etc etc)... if not, look for some broken wires or a connector that might not be connected... I would first re-check all the fuses (under hood and under steering wheel... or where ever the license plate lights fuse is located via the owners manual) Link to comment Share on other sites More sharing options...
SpecBGuy Posted January 13, 2011 Share Posted January 13, 2011 check the wires if theres any power going through it. i had LED on mine and it started blinking on and off so i switched to another bulb thats similar to stock but more on the blue side Link to comment Share on other sites More sharing options...
photog Posted January 14, 2011 Author Share Posted January 14, 2011 I'll check the leads with a DMM today. Link to comment Share on other sites More sharing options...
EmuChicken Posted March 24, 2014 Share Posted March 24, 2014 Currently experiencing the same problem. Did you find a solution? Link to comment Share on other sites More sharing options...
photog Posted March 24, 2014 Author Share Posted March 24, 2014 I had to take the interior plastic panel off of the hatch. There was a wire in there that was connected with a loose fitting connector. I cut it out and soldered it instead. I basically worked backwards with a DMM from the bulbs to where I first started getting voltage. Link to comment Share on other sites More sharing options...
