tangcla Posted September 30, 2009 Share Posted September 30, 2009 If I'm looking at getting the AV panel from Japan, I have the option of ordering the facia with single- and dual-zone climate control panels. Being a pre-facelift (04-06, or 05-07 in your years since you guys are so behind ) it's a single-zone from the factory. Does changing it to the dual-zone panel mean that I can then get dual-zone climate control? Link to comment Share on other sites More sharing options...
Darkness of Death Posted September 30, 2009 Share Posted September 30, 2009 i've read that it doesn't work out. people have tried it and given up. unless there's some new info on it Link to comment Share on other sites More sharing options...
zmarko Posted September 30, 2009 Share Posted September 30, 2009 If I'm looking at getting the AV panel from Japan, I have the option of ordering the facia with single- and dual-zone climate control panels. Being a pre-facelift (04-06, or 05-07 in your years since you guys are so behind ) it's a single-zone from the factory. Does changing it to the dual-zone panel mean that I can then get dual-zone climate control? From everything I've read over the years when people were trying to swap from dual zone to single zone, it can't be done. The control module's are different (not located in the HU fascia itself), and even part of things are run by the ECU, which is all tied in together so you can just swap out modules either. This is all from memory from 3-4 years ago, and certainly not for the Australian market, so this info may not even apply to you. Trust me, the dual zone is more of a pain in the ass than it's worth (of course I'm not married though). Link to comment Share on other sites More sharing options...
