seiyafan Posted June 15, 2017 Share Posted June 15, 2017 Took my car for an alignment today, was told the inner tie rod needs to be replaced because it's getting difficult to turn. Quote was $225, just want to check if this is reasonable, Car had 75k miles and this was my first time been told about replacing tie rod. Link to comment Share on other sites More sharing options...
FLlegacy Posted June 16, 2017 Share Posted June 16, 2017 Sounds like a suspicious diagnosis, the inner tie rod doesn't have much to do with turning effort. good vid Link to comment Share on other sites More sharing options...
cww516 Posted June 16, 2017 Share Posted June 16, 2017 Probably meant "turn" as in "adjust". If that's the case, soak it in PB Blaster to melt the rust off. It's not like you need to regularly run a tie rod through its full range, so as long as they didn't round off the lock nut, you're probably in good shape. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted June 16, 2017 Share Posted June 16, 2017 They're lying and being lazy. Living in the North East these things happen. Map gas or acetylene can fix the problem and not cost you a dime. The inner tie-rod does turn because it's a ball in socket and threaded on the other end which goes into the outer tie-rod. The toe adjustment is made by loosening the jamb nut and turning the inner tie-rod. I've done thousands of alignments and have never once replaced inner tie-rods due to "being hard to turn". Link to comment Share on other sites More sharing options...
DrD123 Posted June 16, 2017 Share Posted June 16, 2017 usually when the inner tie rod fails, it becomes easier to turn (too much slop in the joint) - haven't really seen/heard of one have the joint lock up... just clean up the threads if that's their issue (wire brush, etc.) Link to comment Share on other sites More sharing options...
GTEASER Posted June 16, 2017 Share Posted June 16, 2017 And the ball and socket of the inner tie rod is behind the bellows on the end of the rack, its shouldn't be getting rusty or dirty in there. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
