CAN: madrig cf parts thread
For those of you who don't know, madrig make carbon fiber parts for the 4th gen Legacy and Outback markets. He makes limited GB runs of parts. He also does custom 1-off parts.
As best as I can, this is a listing of every part of his for sale.
Carbon Fiber 4th gen USDM wagon parts
usdm wagon exhaust garnish: https://legacygt.com/forums/showthread.php/carbon-fiber-exhaust-garnishes-wagon-280124.html
rear garnish trim in camo: https://legacygt.com/forums/showthread.php/rear-garnish-trim-camo-carbon-281397.html
usdm wagon rear quarter panels: https://legacygt.com/forums/showpost.php?p=5950582&postcount=211
Carbon Fiber 4th gen USDM parts
radiator shroud: https://legacygt.com/forums/showthread.php/carbon-fiber-radiator-shroud-281592.html
Seat back cover: https://legacygt.com/forums/showthread.php/carbon-fiber-front-seat-cover-281591.html
Center console panel (edm-specific): https://legacygt.com/forums/showthread.php/center-console-panel-edm-279129.html
Edm console pieces (parts in the pipeline): https://legacygt.com/forums/showthread.php/center-console-panel-edm-279129.html
Wagon zerosports waist wing/spoiler: https://legacygt.com/forums/showthread.php/center-console-panel-edm-279129.html
Cobb air box cover plate: https://legacygt.com/forums/showthread.php/cobb-air-box-cover-plate-carbon-fiber-278136.html
Extended hood scoop: https://legacygt.com/forums/showthread.php/canada-fiberglass-carbon-hod-scoop-extented-281296.html
Order going on this scoop - https://legacygt.com/forums/showthread.php/carbon-hood-scoop-285867.html
Madrig wagon spoiler
https://legacygt.com/forums/showthread.php/legacy-wagon-roof-wing-spoiler-liberal-style-bp5-bp9-sold-268106.html
Edited by boxkita
added edm console & waist spoiler options
  • 2 weeks later...
To stick my nose in and also because I'm curious.
In most cases, that pretty weave is a top layer and not at all what carbon fiber looks like. You make a mold and fill it with carbon fiber resin similar to fiberglass. Then pull it out and put a nice pretty layer and top and resin over that and everyone loses their mind.
That's not the only way to do it but common for mass market. In that theory, sure, it's like a big sheet you'd wrap around something and resin in place. But idk if that's Madrigs process (would love to know) and idk if it's worth his time.
I also don't think @ works on here but I could be wrong.
Since Madrig doesn't comment on this thread, I'll tell how I was taught at a custom shop.
put the cf in first, then resin, repeating for each layer. Usually 3 layers. put in vacuum bag and suck out the air/excess resin. then put the whole thing in a furnace for a bit. when "cooked", remove from furnace. then remove vacuum bag. then carefully remove cf part from mold.
now comes the crappy part. clean up the part by sanding. You haven't lived until you sand cf on a hot humid day. Being careful not to sand through the layers.
When done sanding, clearcoat for that "pretty " look.
I skipped some steps, but that's how it's done in a custom shop.
@Madrig, I've been buying a bunch of rando parts that seem coated with CF Is that something you can do too?
i do not do lay over , the process to cover a piece with one coat of carbon fiber.
let say you want your center console in carbon , you cover it with carbon , coat the carbon many time until is smooth . me i will do a mold of the console then i will build the new piece in the mold and it will be complete carbon .
the look final is also very different , cause the vacuum compressing the fiber .
so me i i only make parts from the mold i create .
  • 3 months later...
How much are the quarters? I'd rather go CF than another steel panel which will just eventually rust out. I'm guessing they are paintable? Not that I don't like the look of CF.....
+1 for what Gear says. That quarter looks amazing. It would be the answer to my constant battle against the rusting rear quarter on the sedan. Guessing those are an entirely different beast, though.
so how soon can you start making them and what's your target price? :)
Yes yes. I'd like to be able to budget for the inevitability of wanting wider wheels/tires to fill out the S402 fenders and need to make room to fit the rears.;)
