gtonstilts Posted August 4, 2020 Share Posted August 4, 2020 Hey everyone I recently started posting a build series for my 05 Outback 2.5xt it is fully built/Ballanced Internals, The B25 Heads are ported, with upgraded springs. The Boost is Delivered by an Eaton M90 Supercharger from a 3.8L Ford Supercoupe. It has Air to water inter cooling. I did a 5Mt Swap from the auto trans. Upgraded fuel system 850cc 65c parallel lines. Custom made 8 Rib crank/Alt pulleys. Turbo system deleted. Spec B Suspension, Summer tires, Weight reduction, It got a new satin black paint job, and so much more check out the channel on YouTube "Boosted Problems" Watch, comment, & Subscribe. your support means a lot ! https://www.youtube.com/channel/UCKiBA3u__mVyWJNaHN1eSOA?view_as=subscriber Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted August 26, 2020 Share Posted August 26, 2020 That is quite the neat project Hey everyone I recently started posting a build series for my 05 Outback 2.5xt it is fully built/Ballanced Internals, The B25 Heads are ported, with upgraded springs. The Boost is Delivered by an Eaton M90 Supercharger from a 3.8L Ford Supercoupe. It has Air to water inter cooling. I did a 5Mt Swap from the auto trans. Upgraded fuel system 850cc 65c parallel lines. Custom made 8 Rib crank/Alt pulleys. Turbo system deleted. Spec B Suspension, Summer tires, Weight reduction, It got a new satin black paint job, and so much more check out the channel on YouTube "Boosted Problems" Watch, comment, & Subscribe. your support means a lot ! https://www.youtube.com/channel/UCKiBA3u__mVyWJNaHN1eSOA?view_as=subscriber Link to comment Share on other sites More sharing options...
1992svx Posted October 26, 2021 Share Posted October 26, 2021 Hello where did you get the 8 rib crank pulley made? Link to comment Share on other sites More sharing options...
zakari Posted May 5, 2022 Share Posted May 5, 2022 Nice project, good luck with the build Link to comment Share on other sites More sharing options...
Max Capacity Posted July 6, 2022 Share Posted July 6, 2022 I would suggest you make a post in the 4th Gen Forum with a link to this, very cool project. Or in the Powertrain forum. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
