PATS4LIFE Posted September 22, 2017 Share Posted September 22, 2017 Hi guys,can anyone tell me the best effected way to remove hard water spots on windows,I’ve tried clay bar but nothing,,suggestion is appreciated,thank you.. Link to comment Share on other sites More sharing options...
securityguy Posted September 22, 2017 Share Posted September 22, 2017 You can buy stuff on-line and at the store to get hard water spots off glass. Same stuff you would use on a glass shower door. Not hard to find. Link to comment Share on other sites More sharing options...
ehsnils Posted September 23, 2017 Share Posted September 23, 2017 Mix a little citric acid or other mild acid into water and try with that. Make it a mild solution and keep to household acids. Then rinse well. Don't pay extremely for stuff that you can get at the local supermarket. Clay bar and similar do a mechanical attack and can leave microscopic scratches that just makes it easier for stuff to stick to the window in the future. Link to comment Share on other sites More sharing options...
PATS4LIFE Posted September 23, 2017 Author Share Posted September 23, 2017 Mix a little citric acid or other mild acid into water and try with that. Make it a mild solution and keep to household acids. Then rinse well. Don't pay extremely for stuff that you can get at the local supermarket. Clay bar and similar do a mechanical attack and can leave microscopic scratches that just makes it easier for stuff to stick to the window in the future. Thanks I’ll give that a try Link to comment Share on other sites More sharing options...
capttris Posted September 23, 2017 Share Posted September 23, 2017 vinegar actually. Only use on glass, not on paint. Pour a little on a paper towel and rub/wipe. If it's already etched in, this probably wont work. Only for fresh spots. Link to comment Share on other sites More sharing options...
PATS4LIFE Posted September 23, 2017 Author Share Posted September 23, 2017 vinegar actually. Only use on glass, not on paint. Pour a little on a paper towel and rub/wipe. If it's already etched in, this probably wont work. Only for fresh spots.yeah it’s aready etched in. Link to comment Share on other sites More sharing options...
Subieman Posted September 26, 2017 Share Posted September 26, 2017 McKees 37 makes 2 products for the removal of water spots. You could give one of them a try. First is the regular duty: http://www.mckees37.com/mk37-fast-water-spot-removal-kit.html Second is heavy duty: http://www.mckees37.com/mk37-heavy-duty-water-spot-removal-kit.html Hope that helps Link to comment Share on other sites More sharing options...
