JLW7123 Posted October 8, 2012 Share Posted October 8, 2012 I am going to be putting a sub and amp in and I was wondering what is the best way to route the power wire through the firewall and how do the rear seat come apart. Link to comment Share on other sites More sharing options...
angeltalin Posted October 8, 2012 Share Posted October 8, 2012 There is a small grommet in the firewall under the top mount it Prolly has a rubber plug in the hole. The wire can be attatched to wire clothes hanger to be fished through and should come out to your pedal area. The back seat just pulls up straight in my 05 Prolly the same for other years StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
.blackgt. Posted October 8, 2012 Share Posted October 8, 2012 The grommet is the rubber plug. It is going to come out in the drivers footwell and you just need to slice an x in it to pass the wire. I cannot comment on the 05 seats. Never pulled one, but I assume it's as easy as the 08's. Post pictures of the system when done. Link to comment Share on other sites More sharing options...
angeltalin Posted October 8, 2012 Share Posted October 8, 2012 Yeah that was kind of bad wording on my post, but im sure anyone could decipher it StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
JLW7123 Posted October 8, 2012 Author Share Posted October 8, 2012 Thank you for the help. Link to comment Share on other sites More sharing options...
.blackgt. Posted October 8, 2012 Share Posted October 8, 2012 Thanked every post and then posted a thank you. Damn you are thankful! And yea I was just helping clear it up. No worries. Link to comment Share on other sites More sharing options...
