mccorry Posted May 15, 2020 Author Share Posted May 15, 2020 Link doesn't work for me... Link to comment Share on other sites More sharing options...
Max Capacity Posted May 15, 2020 Share Posted May 15, 2020 https://legacygt.com/forums/showthread.php/head-job-282673.html Try getting there from post #9 in that thread. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mccorry Posted May 16, 2020 Author Share Posted May 16, 2020 That worked... thanks. I was actually planning on going up to 600 grit to get a fine finish as I've heard the MLS gaskets like a smooth finish... the smoother the better I am told. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 17, 2020 Share Posted May 17, 2020 Glad you could get to it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Furn Posted June 13, 2020 Share Posted June 13, 2020 Nice Link to comment Share on other sites More sharing options...
mccorry Posted January 11, 2021 Author Share Posted January 11, 2021 (edited) Realized I never came back an posted updates.... ended up resurfacing the heads and block decks by hand lapping. I used bluing dye to monitor progress on each. The fire ring imprints were still on the block decks from the first set of head gaskets, so I think that is why they failed after only 60k miles. Here is what the block deck looked like on disassembly... https://photos.app.goo.gl/SZKUrKGjnkkevvMx5 https://photos.app.goo.gl/M7Qw3MmR3PgKQXxg9 https://photos.app.goo.gl/uYq59FiGGgoGURLA6 Edited January 11, 2021 by mccorry Link to comment Share on other sites More sharing options...
mccorry Posted January 11, 2021 Author Share Posted January 11, 2021 Here are the decks after hand lapping.... https://photos.app.goo.gl/yZzZGqq3NWEAQWWb8 https://photos.app.goo.gl/T6iNCGUXCHTv98Bk9 Link to comment Share on other sites More sharing options...
mccorry Posted January 11, 2021 Author Share Posted January 11, 2021 And here are the heads after lapping.. https://photos.app.goo.gl/umRUwXyYy3S2kd158 https://photos.app.goo.gl/gLrsEDeLk5jcRKSf7 Link to comment Share on other sites More sharing options...
Max Capacity Posted January 12, 2021 Share Posted January 12, 2021 The after shot's look good. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Scoobyslack Posted January 16, 2021 Share Posted January 16, 2021 They look really clean and good to go now. Link to comment Share on other sites More sharing options...
