YeuEmMaiMai Posted March 7, 2019 Share Posted March 7, 2019 I am going to change out the projectors at some point this year but right now I have a burned out bulb and I want to install a HID lit in the meantime http://www.morimotohid.com/h7-morimoto-elite.html?carDisplay=2014+Subaru+Legacy&preselect=47335&preselect_restrict=1 The above is essentially plug and play for a 2014 Legacy, correct? http://www.morimotohid.com/morimoto-black-series-clear-lens.html?carDisplay=2014+Subaru+Legacy&preselect=&preselect_restrict=1 Link to comment Share on other sites More sharing options...
Notorious Posted March 7, 2019 Share Posted March 7, 2019 If you’re going to retrofit in the future, these bulbs would be only temporary. Paying more money for HIDs that aren’t for an H7 HID projector won’t be different from an amazon kit for $35. They’ll still be an inefficient light spread and have an unclear cutoff. I’d suggest getting a cheaper set. Link to comment Share on other sites More sharing options...
Golferdude1087 Posted March 7, 2019 Share Posted March 7, 2019 I would recommend getting a VLED kit for the H7. You might have second thoughts on HID considering for 150 they are exceptionally bright and have excellent cutoff and little scatter Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted March 7, 2019 Author Share Posted March 7, 2019 problem i have with LED are they do not last... even the expensive ones Link to comment Share on other sites More sharing options...
Wooosh Posted March 7, 2019 Share Posted March 7, 2019 If you’re going to retrofit in the future, these bulbs would be only temporary. Paying more money for HIDs that aren’t for an H7 HID projector won’t be different from an amazon kit for $35. They’ll still be an inefficient light spread and have an unclear cutoff. I’d suggest getting a cheaper set. This [emoji1318]. And then do the retrofit as soon as u can cuz ur halogen projectors aren’t meant for HID bulbs. You may like this better than what you’re looking at. Go get a replacement bulb for $10 for the time being. Full plug n play retrofit, wiring harness and all. Call to verify fitment and ask for a coupon code. They’ll give u at least a 10% off code. Add everything esp the double brights harness (really awesome imo). Mine wound up $270 all said n done. Quality is good and for the $ it’s great. I’ve done a few retrofits from them and they all have worked well and last https://www.theretrofitsource.com/complete-retrofit-kits/morimoto-retroquik-subaru-legacy.html Link to comment Share on other sites More sharing options...
amusa Posted March 8, 2019 Share Posted March 8, 2019 I have HID in my stock housing. It's kind of a pain in the rear on the 2013 to install them. I have a difficult time to get the dust cover back on and locked in place due to tight space. I'm about to upgrade my HID to LED on my other vehicle. I'm just waiting on the mounting clips to arrive. If I like the LED I be getting a set for my JDM SIR-G headlight with TSX retrofit projectors. Link to comment Share on other sites More sharing options...
nads Posted March 11, 2019 Share Posted March 11, 2019 This [emoji1318]. And then do the retrofit as soon as u can cuz ur halogen projectors aren’t meant for HID bulbs. You may like this better than what you’re looking at. Go get a replacement bulb for $10 for the time being. Full plug n play retrofit, wiring harness and all. Call to verify fitment and ask for a coupon code. They’ll give u at least a 10% off code. Add everything esp the double brights harness (really awesome imo). Mine wound up $270 all said n done. Quality is good and for the $ it’s great. I’ve done a few retrofits from them and they all have worked well and last https://www.theretrofitsource.com/complete-retrofit-kits/morimoto-retroquik-subaru-legacy.html This. You wont regret the TRS full swap. Been using mine over 2 years and have 3 three rough winters of getting beat up. I have yet to need to replace anything but assume I will in the next few years. Link to comment Share on other sites More sharing options...
fedaykin Posted March 13, 2019 Share Posted March 13, 2019 I have HID in my stock housing. It's kind of a pain in the rear on the 2013 to install them. I have a difficult time to get the dust cover back on and locked in place due to tight space. I'm about to upgrade my HID to LED on my other vehicle. I'm just waiting on the mounting clips to arrive. If I like the LED I be getting a set for my JDM SIR-G headlight with TSX retrofit projectors. Upgrade your HID to LED? What? Do you mean D2S LED bulb? If so, hah, good luck with that. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted April 19, 2019 Author Share Posted April 19, 2019 OK update on this. Since I do not have the time, the equipment, nor the desire to spend nearly a grand on retrofitting projectors into new Subaru headlight assemblies, I went with the H7 retrofit kit from Miromoto. For those of you saying that the HID will not work well in the stock projectors well that is 100% not true... The beam pattern is identical except for it is significantly brighter. and you are not going to blind people with the eyebrows used for illuminating signs as that light is very dim just like the halogens were. The only thing different I have to do is change the A style bulbs to the B style as the wire causes a shadow in the light output.. a slight annoyance. Link to comment Share on other sites More sharing options...
nads Posted April 20, 2019 Share Posted April 20, 2019 The downside to the stock projector housing is that it is made of plastic and could be prone to burning the bowl which will diminish light output, so that is the potential risk over time. Just something to lookout for if you start to see the performance degrade. What temp color of bulb did you get? Link to comment Share on other sites More sharing options...
amusa Posted April 22, 2019 Share Posted April 22, 2019 Upgrade your HID to LED? What? Do you mean D2S LED bulb? If so, hah, good luck with that. TSX projectors uses D2S. D2S LED's https://www.amazon.com/MOSTPLUS-LED-TX1860-Headlight-Conversion-Warranty/dp/B07KP9RFPZ/ref=sr_1_3?crid=G727U31WN06D&keywords=d2s+led&qid=1555926961&s=gateway&sprefix=d2s+led%2Caps%2C119&sr=8-3 Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted April 22, 2019 Author Share Posted April 22, 2019 The downside to the stock projector housing is that it is made of plastic and could be prone to burning the bowl which will diminish light output, so that is the potential risk over time. Just something to lookout for if you start to see the performance degrade. What temp color of bulb did you get? just curious, halogens put out a lot more heat than hid do, how would they burn the bowl? (yes I know the hid has a hotter hot spot temp wise but it is significantly smaller)... they did survive a 10 hour drive with no change in light output... TSX projectors uses D2S. D2S LED's https://www.amazon.com/MOSTPLUS-LED-TX1860-Headlight-Conversion-Warranty/dp/B07KP9RFPZ/ref=sr_1_3?crid=G727U31WN06D&keywords=d2s+led&qid=1555926961&s=gateway&sprefix=d2s+led%2Caps%2C119&sr=8-3 given the quality of Acura's OEM HID setup, i am pretty sure the LED is going to be a significant downgrade in terms of usable light... now compared to a cheap chinese HID Kit, you might see an improvement Link to comment Share on other sites More sharing options...
fedaykin Posted April 23, 2019 Share Posted April 23, 2019 Heat doesn't burn the bowls, UV does. Link to comment Share on other sites More sharing options...
amusa Posted April 24, 2019 Share Posted April 24, 2019 just curious, halogens put out a lot more heat than hid do, how would they burn the bowl? (yes I know the hid has a hotter hot spot temp wise but it is significantly smaller)... they did survive a 10 hour drive with no change in light output... given the quality of Acura's OEM HID setup, i am pretty sure the LED is going to be a significant downgrade in terms of usable light... now compared to a cheap chinese HID Kit, you might see an improvement I'm using aftermarket HID kit inside a JDM SIR-G headlamps retrofitted with OEM TSX projector. Link to comment Share on other sites More sharing options...
