Ferdaous Posted September 25, 2015 Share Posted September 25, 2015 Hi All, I am after some advice on whether to use 5w-30 or 5w-40 on my JDM Legacy BP5 twinscroll. I am not sure what engine oil to use, 5w30 or 5w-40. The Japanese service book recommends 5w30 but that is if you are using the car in Japan as it snows quite a bit out there and may be colder than in England (this is where the car is driven now). I don't feel like using 5w30 as I used it before (namely Castrol FST 5w-30) on a Legacy BH5 and I felt it didn't suit the car. Would 5w40 be a better choice? Anyone out there used Castrol Edge TITANIUM 5w40? Any advice? Thank you. Ferdaous Link to comment Share on other sites More sharing options...
GTTuner Posted September 25, 2015 Share Posted September 25, 2015 I use 5w40 Castrol religiously, winter and summer. No issues. Link to comment Share on other sites More sharing options...
Mike07LGT Posted September 25, 2015 Share Posted September 25, 2015 why would you feel that 5w30 didnt suit the car? both the US and Japan recommend using 5w30. Most people here use 5w40, so it really is a matter of opinion. I use Motul 8100 5w30, and I have used that in every subaru I own and have never had an issue. So basically use what you want, as long as its synthetic and not Mobil 1 you should be fine 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
Max Capacity Posted September 25, 2015 Share Posted September 25, 2015 I use 5w-40 year round in both my Legacy's. The 40 is much better when the engine is warm and running. It doesn't break down to a 20 like a lot of the 5w-30's do. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Ferdaous Posted September 25, 2015 Author Share Posted September 25, 2015 Thank you guys for the advice. Will go with 5w-40. Just for the records when I said 5w-30 didn't suit that BH5 I used to own, it wasn't because of the oil, the car had a weak engine. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 25, 2015 Share Posted September 25, 2015 There is a "what oil should I use" thread here, that hasn't been kicked to the top in a while now. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GTTuner Posted September 26, 2015 Share Posted September 26, 2015 why would you feel that 5w30 didnt suit the car? both the US and Japan recommend using 5w30. Most people here use 5w40, so it really is a matter of opinion. I use Motul 8100 5w30, and I have used that in every subaru I own and have never had an issue. So basically use what you want, as long as its synthetic and not Mobil 1 you should be fine Because I've had good experience with it. Link to comment Share on other sites More sharing options...
Mike07LGT Posted September 27, 2015 Share Posted September 27, 2015 Because I've had good experience with it. I was asking original poster why he felt 5w30 didn't suit the car... 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
08 LGT Posted September 27, 2015 Share Posted September 27, 2015 Most people here recommend Shell Rotella T6 5w-40, and used oil analysis confirms it pairs great with these engines (very low wear). The bottle says it's for diesel, but ignore that, it doesn't matter. Link to comment Share on other sites More sharing options...
rapture Posted September 27, 2015 Share Posted September 27, 2015 Soo Ive used t6 for awhile now But was just told that they switched formulas? About 6 months ago? Anybody confirm this? Ive switched to the new natural gas pennzoil platinum ultra Ive seen LESS consumption/burnoff so far than the t6 Could this be contribited to the newer t6 formula? Link to comment Share on other sites More sharing options...
08 LGT Posted September 28, 2015 Share Posted September 28, 2015 Couldn't tell you, I've never had a problem with oil consumption before or after switching to T6 Link to comment Share on other sites More sharing options...
apexi Posted September 28, 2015 Share Posted September 28, 2015 Gas to liquid base oil is supposed to have low noack volatility, which can mean reduced oil consumption. Noack volatility is basically the evaporation rate of the oil. More information in the links below. Chances are the reduced consumption is from using the low noack pennzoil platinum ultra, and not a formula change with the t6, that's just my guess though. http://www.pqiamerica.com/Testdescriptions/Noack.html http://www.machinerylubrication.com/Read/533/base-oil-trends http://gasprocessingnews.com/features/201410/gtl-innovation-produces-clean-base-oils-from-natural-gas.aspx Link to comment Share on other sites More sharing options...
