Catalyst Posted May 8, 2014 Share Posted May 8, 2014 If I were to turn OFF a P0420 in my wifes 2009 Legacy NA using romraider/ecuflash, would it pass CT emissions (OBDII reader) or would it tell them the code has been turned off and then fail? I have a Vag-com for my car but would need a Tactrix for a 2009, correct? "This is an adventure." Link to comment Share on other sites More sharing options...
Nrw Posted May 8, 2014 Share Posted May 8, 2014 If they are anything like MA that would be a fail. Link to comment Share on other sites More sharing options...
Hitokiri_Gensai Posted June 2, 2014 Share Posted June 2, 2014 Well, define, turn off? As in erase the codes? or do you mean to change their values with a computer so that they're "ready". Both are illegal to do, as a note, but lots of people do it. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 4, 2014 Share Posted June 4, 2014 You need to fix the issue, or delete the code forever. If you just reset the ECU, take it to testing without driving it 60 miles or more, they can tell the ecu was reset. The 420 code is the front O2 sensor, in most cases. Use a OEM one. I know some of the 2.5i had cat issues too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bluesuby Posted June 4, 2014 Share Posted June 4, 2014 You need to fix the issue, or delete the code forever. If you just reset the ECU, take it to testing without driving it 60 miles or more, they can tell the ecu was reset. The 420 code is the front O2 sensor, in most cases. Use a OEM one. I know some of the 2.5i had cat issues too. In NJ I was told to put more miles on the car before testing. I had replaced the battery (without having any codes thrown) but the computer at inspection said the car had insufficient miles to accrue the data needed for testing. Link to comment Share on other sites More sharing options...
liljonson Posted June 4, 2014 Share Posted June 4, 2014 needs to see all the monitors have passed. Takes up to 2 drive cycles Link to comment Share on other sites More sharing options...
