BILSTEIN B6 problem on my 04' 3.0R sedan
Hi everyone.
I did some upgrades on my 04' 3.0R sedan 2 weeks ago.
I changed all the OEM shocks for 4 Bilstein B6. Added to the shocks I bought new front and rear strutmount.
I did not change the springs.
After 4 days, chassis setting was done.
But i checked the weel arch height (from the wheel's center to the lowest point of the wheel arch) and got the following results :
Front : 400mm instead of 378 (tolerance +/- 12mm)
Rear : 350mm instead of 360 (tolerance +/- 12mm)
Added to the height, front shocks are as hard as hell.
Is that normal ? What did i do wrong ?
Will the front stay like this or not even after weeks of rides ?
Will the ride quality change ?
Any solution to fix that small issue
Thanks for your advices and sorry for my so bad english
Register a new account
Sign in
