Falcor's 2011 2.5GT - Build Thread
Engine
- COBB AccessPort V3 (AP3-SUB-003)
- Fumoto Drain (F-108)
Drivetrain
- Perrin 2015 WRX Shifter Bushing (PSP-INR-016)
- Clutch Damper Delete
- Subaru OEM 2015+ WRX Short Throw Shifter (C1010VA000)
- Perrin 2015+ WRX Shifter Stop (PSP-INR-019)
- Boomba shift plate
Steering
- Perrin Steering Dampener Lockdown ( PSP-SUS-565)
Exhaust
- Nameless Axleback with 5" Mufflers
Suspension
- 20mm Rear Sway Bar (20451VA000)
- Legacy Sport rear subframe support (20157AJ040)
- Eibach PRO-KIT Performance Springs (7722.140)
- Cusco Rear Power Brace ( 687 492 RS)
- Koni Front - 8610 1447Sport; Rear - 8010 1055Sport
- KYB Top Hats (SM5361)
- KYB Excel-G front donor struts (339222 and 339223)
- Adjustable Rear Lower Control Arms (RS28150005)
- Moog Rear Top Hats (K160377)
Brakes
- Wearever Platinum Ceramic brake pads
Wheels & Tires
- Stock GT Wheels
- General Tire G-Max AS-05 225/45R18
- STI center caps
- 20mm front and 22mm rear wheel spacers
Cosmetic - Exterior
- German front plate
- COBB rear license plate frame
Cosmetic - Interior
- 2010 acrylic cupholder ring
- Illuminated cupholder mod
- Fuse box door bin
- Red STI shift knob (35022VA000)
Interior
- Stuffed front seat bolsters - Thread (https://legacygt.com/forums/showthread.php/diy-bucket-seats-258543.html)
Exterior Lighting
- Lamin-x yellow foglight covers
- JDM Clone OEM headlights (opened up and painted)
- Klearz smoked headlight markers
- Low Beam: VLEDs Micro Extreme LED H7 5000K
- Front Turn Signal: Super Bright LEDs 7440/7443 CK LED Bulb - Dual Function 27 SMD Tower (amber)
- Front Side Marker: VLEDS High Power Amber 14 LED 194
- Factory Puddle Lights (H471SAJ100)
- VLEDs 194 5k city bulbs
Interior Lighting
- LED interior lighting - superbrightleds.com
Not Yet Installed
- Replacement console cover (original scratched by dealer)
- Lamin-X Door handle cup guards
Edited by Falcor
  • 1 month later...
  • 4 weeks later...
Installed the Boomba shift plate on Saturday. It took a bit longer than I expected since I ended up removing the entire cross member so I could get a good swing to drive out the roll pin. The feel is quite a bit different but I do like it.
Before:
After:
Edited by Falcor
Thanks for the enabling, but I think I'm done with everything that has to do with the shifter now.
I have 4 main areas I want to address now:
Suspension - Koni or Cusco
Exhaust - probably just axle back
Window Tint
Etune - something like Cryotune
  • 1 month later...
Installed the Lamin-x yellow fog light overlays. When sticking them on, I remembered seeing on here that they do not cover the entire lens and a different one covers better. So I centered them up the best I could. All in all, I like the look. Time will tell if they actually help in fog light needed situations.
Suspension - Koni or Cusco Koni
Exhaust - probably just axle back Yes
Window Tint Duh, but don't go too dark
Etune - something like Your car will come ALIVE!
  • 2 weeks later...
Would those work on a 3.6R? I feel like somebody told me the pipes are the same on the GT and the 3.6R.
The guy I bought them from has a 3.6 so they definitely fit.
Sent from my SM-G965U using Tapatalk
I would love to get these, but there is no way my wife would let me now that I have the headlight project starting up. And hopefully suspension soon.
If air suspension wasn't $2k I would make you a package deal with my koni setup, lol. But I cant stomach that price, lol.
Hmm. I’d been planning to get the Nameless axle backs with the mufflers at some point. Maybe this would fit the bill...
Keep in mind they are discontinued so you'll have to buy FL's or find another set used.
