LGT05tsully691 Posted July 19, 2014 Share Posted July 19, 2014 Hey new to this forum, I have an 05 lgt 5mt. My clutch is on it's way out. Decided to replace this weekend. I'm going to drop the rear drive shaft and slide the tranny to the rear of the car to replace the clutch do you guys have any tips? And or any problems commonly run into while doing this? Thanks Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
FknBoss Posted July 19, 2014 Share Posted July 19, 2014 It's simpile. Like doing a rwd clutch but has 2 axles coming out of it lol. Pull the intercooler to get most of the bolts from up top. Link to comment Share on other sites More sharing options...
LGT05tsully691 Posted July 19, 2014 Author Share Posted July 19, 2014 Should I disconnect the cv shafts or is there enough play to work with? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
FknBoss Posted July 19, 2014 Share Posted July 19, 2014 Disconnect them Link to comment Share on other sites More sharing options...
LGT05tsully691 Posted July 21, 2014 Author Share Posted July 21, 2014 Everything went well, first clutch job was easier than I thought. but was a pain when separating the bell housing from the motor Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
FknBoss Posted July 21, 2014 Share Posted July 21, 2014 Always are. They get corrosion from years of being bolted together Link to comment Share on other sites More sharing options...
Max Capacity Posted July 21, 2014 Share Posted July 21, 2014 Good Job. Do you know what to use for the tranny fluid ? Oh, Welcome to the forum. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LGT05tsully691 Posted July 21, 2014 Author Share Posted July 21, 2014 I didn't change the tranny fluid looked clean, not sure what to use? For future referance Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Gex Posted July 21, 2014 Share Posted July 21, 2014 Use Extra S in the trans. Can be bought by the quart from site Vendors such as Infamous and Fred Beans Parts. I think the tranny uses 3.5qts. Link to comment Share on other sites More sharing options...
LGT05tsully691 Posted July 21, 2014 Author Share Posted July 21, 2014 Awesome good info thanks! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted July 21, 2014 Share Posted July 21, 2014 3.8qt's The tranny must be rear end high to drain all the old stuff out. it can be a pain. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
