Suspension Squeak - Front (2005 LGT)
Car has 65,000 miles. In the last 2,000 miles, it's developed a squeak in the front suspension, when always under compression.
Ex: hitting a speed bump at 3 mph that causes the suspenion to compress more than 1 inch.
Happens regardless if it's one or both sides that compress. Not a high pitch squeek, sounds like a dulled, rubber on rubber with no lube squeek.
I can't find it. Any advice? I didn't see any grease zirks under there.
Stock suspension, Rallitek Swaway and endlinks.
Thanks in advance.
BANNED FROM THE TIKI FORUM. :lol:
  • Replies 52
  • Created
  • Last Reply
Sadly, all of the bushings on these cars are the "maintenance free" kind so no place to really lubricate something.
Assuming from your post that it doesn't matter which side compresses it'll still squeak?
My first thought would be a bad sway bar end link or bushing since that's the part of the suspension that "should" move regardless of the side compressing.
I replaced both end links and bushings (actually the whole bar too) at 65k on my '06 and the stock ones were all in pretty bad shape. Since you have aftermarket sway and endlinks, I would still pull them and give them a thorough inspection before ruling them out.
Regreased the sway bar mounts (they have poly bushings with the own grease - I cleaned them up and threw in some Mobil 1 synthetic).
How would I grease the LCA bushings, outside of removing the LCA's and pushing them out with a press?
The dampening on the struts on there, I'll check again tonight.
As for the LCA bushings, do both front and rear?
http://www.whiteline.com.au/product_detail4.php?part_number=W0506
http://www.whiteline.com.au/product_detail4.php?part_number=W53353
Anyone got a write up, and any vendors that sell both in a kit?
I would replace both bushings while you have the lca off. Do it once. IMO the offset positive caster lca bushings (hockey puck sized ones) are one of my favorite suspension mods to the car. As Myles from RCE has told me before, "caster is like sex and money, you can never have enough"
lol lca bushings are not greasable. they are disposable. lifespan of 50k miles. get whitelines
This.
front inners are very unecessary, oem ones never wear out, and in actuality are more of a pita to press out than the round ones.
If you're going to take off the LCA, I recommend replacing the inners with Whiteline. I did mine and it made a nice improvement in turning response.
Took mine down to a machine shop and they pressed all 4 out/in for $30 bucks. Well worth it.
My wife's balls are delicious.
This ones on the house.
http://legacygt.com/i/customavatars/avatar39424_89.gifhttp://legacygt.com/i/customavatars/avatar30799_1.gifhttp://legacygt.com/i/customavatars/avatar13509_6.gif
:lol:
