Ajfrassetto Posted September 22, 2015 Share Posted September 22, 2015 hey man. just looking over the build and looks badass. same route in heading for. Im new to the subaru thing, but just curious. 11.66 is the fastest a legacy has been? Link to comment Share on other sites More sharing options...
KBGRIZZLY64 Posted September 22, 2015 Share Posted September 22, 2015 Awdtuning spec.B hit 10s a month ago Sent from my VS986 using Tapatalk Priorities change when car parts come into the equation Link to comment Share on other sites More sharing options...
Ajfrassetto Posted September 22, 2015 Share Posted September 22, 2015 That's crazy. The amount of performance parts and technology and the fastest legacy is running 10s. Not knocking it, just suprised Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 22, 2015 Share Posted September 22, 2015 It could run 9.6 something like this car: [ame=http://www.youtube.com/watch?v=Jxk4Pt55pp8]NEW RECORD: AMS Equipped 2015 Subaru STI Runs 9.681@147.39mph! - YouTube[/ame] Link to comment Share on other sites More sharing options...
jmorris6689 Posted September 24, 2015 Author Share Posted September 24, 2015 Yeah when it went 11.66 it was making about 100whp less then it currently is. Link to comment Share on other sites More sharing options...
jmorris6689 Posted March 17, 2016 Author Share Posted March 17, 2016 Well mary is whooping my ass. And there is no end in sight to this ass whooping, there are so many legacies making big numbers now. That being said since my last post I have installed a new way bigger radiator, got the fueling system sorted out. And at this moment I am getting a rotated setup fabricated for my new turbo. I will be adding new fueling system components with the new turbo after some time to re coupe my savings. The fuel systems that is going in it will be the one I will use for the new engine when ever I get around to that (hopefully later this year or possibly next year. So here are the details on the new parts, I have a Borg Warner s300sx e 75lb per min turbo 62mm compressor wheel; mishimoto aluminum radiator, omni 4 bar map sensor, and a tial 38mm Mvs waste gate, new intercooler pipes are being fabricated as well as my tomei up pipe is being turned into a rotated up pipe. Fuel system parts have not been purchased yet but it will be along the lines of a high flow 400ish lph pump in tank feeding a surge tank feeding a magafuel 750 to -8 feed lines to my already installed aeromotive rails then to my adjustable fpr returning to the surge tank via -6 line which will over flow back into the factory tank. I will post picture as I go Link to comment Share on other sites More sharing options...
Rattsl Posted March 17, 2016 Share Posted March 17, 2016 Well mary is whooping my ass. And there is no end in sight to this ass whooping, there are so many legacies making big numbers now. That being said since my last post I have installed a new way bigger radiator, got the fueling system sorted out. And at this moment I am getting a rotated setup fabricated for my new turbo. I will be adding new fueling system components with the new turbo after some time to re coupe my savings. The fuel systems that is going in it will be the one I will use for the new engine when ever I get around to that (hopefully later this year or possibly next year. So here are the details on the new parts, I have a Borg Warner s300sx e 75lb per min turbo 62mm compressor wheel; mishimoto aluminum radiator, omni 4 bar map sensor, and a tial 38mm Mvs waste gate, new intercooler pipes are being fabricated as well as my tomei up pipe is being turned into a rotated up pipe. Fuel system parts have not been purchased yet but it will be along the lines of a high flow 400ish lph pump in tank feeding a surge tank feeding a magafuel 750 to -8 feed lines to my already installed aeromotive rails then to my adjustable fpr returning to the surge tank via -6 line which will over flow back into the factory tank. I will post picture as I go Seems like some secret weight shedding needs to be done. Mary, Mike, and Doogie are now over 850whp. Mary being at 904, Mike at 856, and Doogie around the same as Mike (Same tuner I believe). Link to comment Share on other sites More sharing options...
jmorris6689 Posted March 17, 2016 Author Share Posted March 17, 2016 I'll get around to that eventually I need to get the next engine together first. Link to comment Share on other sites More sharing options...
Z0rr0 Posted March 21, 2016 Share Posted March 21, 2016 Well mary is whooping my ass. And there is no end in sight to this ass whooping, there are so many legacies making big numbers now. That being said since my last post I have installed a new way bigger radiator, got the fueling system sorted out. And at this moment I am getting a rotated setup fabricated for my new turbo. I will be adding new fueling system components with the new turbo after some time to re coupe my savings. The fuel systems that is going in it will be the one I will use for the new engine when ever I get around to that (hopefully later this year or possibly next year. So here are the details on the new parts, I have a Borg Warner s300sx e 75lb per min turbo 62mm compressor wheel; mishimoto aluminum radiator, omni 4 bar map sensor, and a tial 38mm Mvs waste gate, new intercooler pipes are being fabricated as well as my tomei up pipe is being turned into a rotated up pipe. Fuel system parts have not been purchased yet but it will be along the lines of a high flow 400ish lph pump in tank feeding a surge tank feeding a magafuel 750 to -8 feed lines to my already installed aeromotive rails then to my adjustable fpr returning to the surge tank via -6 line which will over flow back into the factory tank. I will post picture as I go Someone listened to me about the fuel system Link to comment Share on other sites More sharing options...
jmorris6689 Posted March 22, 2016 Author Share Posted March 22, 2016 It's hard to argue with someone who has experience and owns their own shop. I appreciate all the help and advice you have given me over the past few years. When ever it comes time for me to get the next engine built I would love to give you my business Link to comment Share on other sites More sharing options...
jmorris6689 Posted April 2, 2016 Author Share Posted April 2, 2016 The waste gate is here turbo is ordered fabrication is starting next week. Should be back on the road in a month or so Link to comment Share on other sites More sharing options...
Z0rr0 Posted April 19, 2016 Share Posted April 19, 2016 It's hard to argue with someone who has experience and owns their own shop. I appreciate all the help and advice you have given me over the past few years. When ever it comes time for me to get the next engine built I would love to give you my business People do it all the time Link to comment Share on other sites More sharing options...
Max Capacity Posted April 22, 2016 Share Posted April 22, 2016 (edited) Thanks for the updates...some of us do check in every now and then. Do you plan to drive the car or just race it ? When our Civic ran low 11's my son decided it was no longer safe as a street car. That's when we began to spend big money, think 40FT enclosed 5th wheel. That was fun for a few years. Edited April 22, 2016 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jmorris6689 Posted April 26, 2016 Author Share Posted April 26, 2016 I plan on driving it and having it still as a registered vehicle. But I am currently looking at buying a tow vehicle. Trying to find a nice nissian armada in white to match the car haha. But I plan on still driving the car to meets and shows and maybe the occasional day at the drag strip. If I can get into actually tracking the car then I will hopefully be towing it. Link to comment Share on other sites More sharing options...
Th3Franz Posted April 26, 2016 Share Posted April 26, 2016 What rear axles are you going with? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
jmorris6689 Posted April 27, 2016 Author Share Posted April 27, 2016 As of right now I'm going with the ones I have haha (07-09 spec b) I would like to buy some upgraded axles and I spoke to a guy who owns a shop here locally who builds some high horsepower bmw and he said he will try and hook me up with some Texas axle shop. So that may be an option if not then I will have to save up and get the drive shaft shop axles. As of right now I'm trying to save for some bigger brake calipers and a set of nice coilovers. Link to comment Share on other sites More sharing options...
jmorris6689 Posted April 27, 2016 Author Share Posted April 27, 2016 http://i499.photobucket.com/albums/rr353/jmorris6689/Mobile%20Uploads/2016-04/4A30F753-C773-4A97-910C-F53174D480EE.jpg Link to comment Share on other sites More sharing options...
jmorris6689 Posted April 27, 2016 Author Share Posted April 27, 2016 http://i499.photobucket.com/albums/rr353/jmorris6689/Mobile%20Uploads/2016-04/9B658B9F-0DE3-4D4D-BD22-19D589DB7143.jpg http://i499.photobucket.com/albums/rr353/jmorris6689/Mobile%20Uploads/2016-04/98DD6F61-933C-4418-90D5-105BF16DCC97.jpg http://i499.photobucket.com/albums/rr353/jmorris6689/Mobile%20Uploads/2016-04/01D77319-122E-4632-B1A8-99AB5690DED4.jpg http://i499.photobucket.com/albums/rr353/jmorris6689/Mobile%20Uploads/2016-04/68CF3DA3-9EE9-4F0E-95CC-0BB5FEC4732E.jpg Link to comment Share on other sites More sharing options...
jslayz Posted April 27, 2016 Share Posted April 27, 2016 Heck yeah!! BW looks the biz. Good luck!! Link to comment Share on other sites More sharing options...
Th3Franz Posted April 28, 2016 Share Posted April 28, 2016 Nice turbo. Definitely looks 75 lb/min -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
jmorris6689 Posted June 7, 2016 Author Share Posted June 7, 2016 Update pictures... http://i499.photobucket.com/albums/rr353/jmorris6689/6D184344-9ED7-43A4-8BF5-0D754154B45B_3.jpg http://i499.photobucket.com/albums/rr353/jmorris6689/AC1881CA-078D-41C6-9C42-4619C4BFEB9A.jpg http://i499.photobucket.com/albums/rr353/jmorris6689/095535AC-2D95-45F0-BF28-AC4E99CD14C2.jpg http://i499.photobucket.com/albums/rr353/jmorris6689/5E9E15D1-A356-47A2-9617-E8A9FFB67C8D.jpg http://i499.photobucket.com/albums/rr353/jmorris6689/22B672FF-6666-46EA-A31C-44D6DED42A45.jpg http://i499.photobucket.com/albums/rr353/jmorris6689/410D37F4-B989-4659-8CEC-3D9A88B41990.jpg Link to comment Share on other sites More sharing options...
jmorris6689 Posted June 11, 2016 Author Share Posted June 11, 2016 Went and saw my car yesterday, and I must say it looks amazing in person. I've also been busy buying up some more parts, I have ordered a set of coilovers bc br with swift springs and custom spring rates 10kfront and 8k rear. I also bought a big brake kit from a fellow member on here. Then I got a ptp turbo blanket for the new turbo. The car should be ready either late next week or early the week after that! I'll post up some more picture after its done with powder coating. Link to comment Share on other sites More sharing options...
JSaladino Posted June 11, 2016 Share Posted June 11, 2016 Oooooooh damn it looks good!! Can't wait to see it! Link to comment Share on other sites More sharing options...
jmorris6689 Posted June 12, 2016 Author Share Posted June 12, 2016 Dude where have you been?! I haven't seen you since winter time. I hope all is well and that you're a doctor now Link to comment Share on other sites More sharing options...
JSaladino Posted June 12, 2016 Share Posted June 12, 2016 I've been all over man, was out in Crossville for 6 weeks, in Athens for 6 weeks, and I'm just finishing up 6 weeks in Greeneville. Haha still got 6 months to go, then I'll be out! Doing pretty well though, going to be back in Knoxville for the next 6 weeks, so I'm hoping to make it out to some meets. How's it going for you man?? You had that beast on a dyno yet? Link to comment Share on other sites More sharing options...
