gimpydingo Posted August 27, 2019 Share Posted August 27, 2019 I've been battling exhaust leaks for quite a while now. Once I get everything sealed it's only a matter of time before I get leaks again at the manifold/crossover pipe. It's always the passenger side. I have used the Grimm thicker gaskets and the copper spray gasket and issue still pops up. Any suggestions? I've gone through all the posts regarding this and I cannot get it to seal. :spin: Link to comment Share on other sites More sharing options...
Max Capacity Posted August 27, 2019 Share Posted August 27, 2019 Red RTV silicone sealant. Put a bead on one side of the gasket. let it tack up for about 12 minutes. stick it to one of the flanges. put a bead on the exposed side of the gasket, let it tack up. assemble the flanges. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
gimpydingo Posted August 27, 2019 Author Share Posted August 27, 2019 Thanks. I'll give the red a try the way you suggest! Link to comment Share on other sites More sharing options...
schwab Posted August 30, 2019 Share Posted August 30, 2019 What max said, no more leaks. Link to comment Share on other sites More sharing options...
gkinslow Posted August 30, 2019 Share Posted August 30, 2019 Make sure your mating surfaces are clean from corrosion and/or carbon buildup. The prep work is as important as using the correct gaskets. Link to comment Share on other sites More sharing options...
gimpydingo Posted September 11, 2019 Author Share Posted September 11, 2019 I got a brush for my drill, cleaned everything, light sanding. Overall everything is smooth. To add to this I took it out for a drive and guess I only finger tightened the downpipe to mainfold bolts. So those opened a bit and car started making the rumble. I limped it home and found my mistake. I got it all buttoned up, checked everything, soaped up the gaskets, even the DP to CBE (OEM) donut/gasket, no leaks. BUT now the car is much louder than it was previously. Sounding more like a truck, which seems to be coming from where the turbo/downpipe meet. If a blip the gas it gets a bit of a backfire/burble sound. I ran RR and pulled a LV. Idle's fine, no misfires. LV shows +4 in A, while B, C, D are 0. My previously leaky LV showed -5 in, while B, C, D were around -1 to -2. So things have shifted a bit. The +4 would be pre turbo right? vac lines and such? I was thinking maybe a crack in the flex of the uppipe (OEM), but that doesn't seem right. With one fix comes two more problems. AMIRIGHT? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 12, 2019 Share Posted September 12, 2019 IMO that flex piece in the up pipe is a weak point. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
gimpydingo Posted September 12, 2019 Author Share Posted September 12, 2019 I'll have to tear into for the UP. I find it odd it would just develop a leak when haven't touched it. I tried to capture the sound, not that amazing over a phone. 2nd vid is quite a bit longer. Link to comment Share on other sites More sharing options...
gimpydingo Posted September 16, 2019 Author Share Posted September 16, 2019 It's both the UP and DP gaskets leaking. I ordered some OEM. Link to comment Share on other sites More sharing options...
gimpydingo Posted September 22, 2019 Author Share Posted September 22, 2019 Always something. Got everything back together and now there is definitely a leak in my UP. I think I must have added to a slight crack it had, time to replace. Recommendations? OEM or aftermarket? Link to comment Share on other sites More sharing options...
awfulwaffle Posted September 22, 2019 Share Posted September 22, 2019 Where's your car at mod-wise? Nothing wrong with aftermarket, but a catless OEM pipe will be cheaper. A friend of mine may have one if you want to go the OEM route. Link to comment Share on other sites More sharing options...
gimpydingo Posted September 22, 2019 Author Share Posted September 22, 2019 Just a DP and tune. It's a 5EAT so keeping it simple. I may be interested depending on miles and $$. Link to comment Share on other sites More sharing options...
awfulwaffle Posted September 22, 2019 Share Posted September 22, 2019 Don't think there's much difference then, aftermarket or OE Link to comment Share on other sites More sharing options...
gimpydingo Posted September 22, 2019 Author Share Posted September 22, 2019 Invidia on the way... Link to comment Share on other sites More sharing options...
gimpydingo Posted September 27, 2019 Author Share Posted September 27, 2019 I guess I should have avoided the Invidia UP. I cannot get the UP to Manifold gasket to seal. I've followed up M Spranks instructions a few times now and no go. :mad::mad::mad::mad::spin::spin: Link to comment Share on other sites More sharing options...
Gabo Posted September 27, 2019 Share Posted September 27, 2019 I guess I should have avoided the Invidia UP. I cannot get the UP to Manifold gasket to seal. I've followed up M Spranks instructions a few times now and no go. :mad::mad::mad::mad::spin::spin: Wish I knew there was a guide. I'm assuming this is applicable to those using an OEM header with an aftermarket uppipe. When I swapped the VF52 with the Dom 1.5 I removed and reinstall my Killer B uppipe and I didn't follow a guide at all. Then again the uppipe is v-band as oppose to bolted. Link to comment Share on other sites More sharing options...
gimpydingo Posted September 27, 2019 Author Share Posted September 27, 2019 Here is what I followed https://legacygt.com/forums/showthread.php/up-pipe-installation-instructions-171933.html I event went back and used a knife to flair the gasket, I tried 2 gaskets. Nothing is working. Really don't want to buy another UP and gasket. Money, money, moneeeeeeeeeeeyyyyyy. Link to comment Share on other sites More sharing options...
gimpydingo Posted September 27, 2019 Author Share Posted September 27, 2019 It doesn't really seem to mate up well with the manifold. I got it from Import Image Racing, so hope they'll take it back. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 28, 2019 Share Posted September 28, 2019 I don't understand why your having such an issue. There must be something wrong with the up pipe. I have installed two and even had the first Invidia up pipe off a few times, never had a issue with a leak. Good Luck 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
gimpydingo Posted September 29, 2019 Author Share Posted September 29, 2019 If the UP isn't bolted to the manifold, the UP flange is off by 1/2 in from manifold flange. Since you've removed yours several times without issues I have to assume there is something wrong with my pipe. Link to comment Share on other sites More sharing options...
awfulwaffle Posted September 29, 2019 Share Posted September 29, 2019 FWIW - I've owned two Invidia catless up-pipes - one that I put on my wagon when I got it and sold with the motor out of it, and one that came with the motor in my parts car that I'm currently using. The first lined up perfectly, and the second is a little bit off in fitment. However, I'm still able to lean into it with a prybar and get the bolts to pass through. Seems like there might be some significantly variability to these things. Neither of mine has leaked after multiple removals/reinstallations with a liberal application of copper spray, though. Link to comment Share on other sites More sharing options...
gimpydingo Posted September 29, 2019 Author Share Posted September 29, 2019 (edited) Yeah I've done it both ways. Finger tight mani, line up with UP, finger tighten UP, tighten mani then UP fully. I've also done as you and strong armed it into place and force bolt through. It sounds good and runs perfect, but if I soap up the flange its leak city. Rest of the gaskets are solid. Seems the GS uppipe is a bit cheaper than OEM and still had the flex. Might go that route. Edited September 29, 2019 by gimpydingo Typo Link to comment Share on other sites More sharing options...
gimpydingo Posted October 1, 2019 Author Share Posted October 1, 2019 Some good news. After sending some pics to Import Image they are giving me an RMA and credit. I guess I'll go with the GS and call it a day. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 1, 2019 Share Posted October 1, 2019 Good to hear they are taking care of you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
gimpydingo Posted October 2, 2019 Author Share Posted October 2, 2019 Me too. Matt over at Import Image was very helpful. After I pulled the invidia UP I realized how much bigger the opening was in compared to the stock manifold. I could see an outline of a ring where the stock gasket was just slightly offset so yeah of course it leaked between that and the flange not 100% matching up. I have 100k miles on the car, so if I have to replace the GS flex in 50k miles or so no big loss. Just....want....it....sealed... Also we are down to 1 car that my wife commutes in. 3.6 is in the body shop and LGT up on jacks. wha wha whaaaaaaaaa Link to comment Share on other sites More sharing options...
