dham Posted September 3, 2018 Share Posted September 3, 2018 08 GT. Car has been having troubles when turning over. Had the battery checked and it is good. Starter doesn't seem to be the issue as it turns and turns. No CEL. Any ideas? Fuel pump? Wouldn't a bad fuel pump produce a code? Link to comment Share on other sites More sharing options...
Marvick08GT Posted September 3, 2018 Share Posted September 3, 2018 No it would not throw a code, it just wouldn't start. A shop would be able to tell you what the issue is. Good luck Link to comment Share on other sites More sharing options...
JmP6889928 Posted September 3, 2018 Share Posted September 3, 2018 Crank sensor Link to comment Share on other sites More sharing options...
relative4 Posted September 3, 2018 Share Posted September 3, 2018 Spray some starting fluid or other flammable spray in the inlet to see if fuel is the problem. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 3, 2018 Share Posted September 3, 2018 Lets start over, by "turn over" do you mean the starter is not engaging and spinning the engine ? that's "not turning over". If your thinking the fuel pump, that would be, no noise from under the rear seat when the key is turned to "On". The engine would turn over but not start or fire up. Car won't turn over is most likely a battery issue or starter. JmP may be on to something with the crank sensor. Here's the service manual for you, http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dham Posted September 3, 2018 Author Share Posted September 3, 2018 Thank you everyone. Crank sensor seemed to be the issue. Couldn't properly test the old unit as I have a free multi-meter from Harbor Freight and it wasn't working right. Just replaced the crank sensor and the car started right up. Link to comment Share on other sites More sharing options...
relative4 Posted September 3, 2018 Share Posted September 3, 2018 JmP, yer a damn psychic. Link to comment Share on other sites More sharing options...
JmP6889928 Posted September 6, 2018 Share Posted September 6, 2018 Not a psychic-just been working on cars for 40+ years...LOL. I fart dust. Link to comment Share on other sites More sharing options...
