Scottydunno Posted August 30, 2018 Share Posted August 30, 2018 Is the assembly from an NA car the same as a GT. I fully well know the pumps themselves are different. I'm trying to get me ducks in order so I can replace stuff that's getting old has been neglected. Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted August 30, 2018 Share Posted August 30, 2018 On the top of the very frist forum here there is a link to "opposedforces" you can check there. Or most dealers now have a on-line parts catalog. check the part for both models. https://legacygt.com/forums/showthread.php/subaru-oem-parts-catalog-online-exploded-views-opposed-forces-130411.html http://people.csail.mit.edu/ilh/vacation/ I see that second link, which is the service manual is not working right now. Here's where it came from. https://legacygt.com/forums/showthread.php/wants-see-my-vacation-pixi-6216.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
utc_pyro Posted August 30, 2018 Share Posted August 30, 2018 The NA cars have the fuel pressure regulator in the bucket, and are missing the return. Thus the entire assembaly isn’t cross comparable. The bottom part of the bucket, level sensor, filter, and pre-filter are computable though. Link to comment Share on other sites More sharing options...
Scottydunno Posted August 30, 2018 Author Share Posted August 30, 2018 The NA cars have the fuel pressure regulator in the bucket, and are missing the return. Thus the entire assembaly isn’t cross comparable. The bottom part of the bucket, level sensor, filter, and pre-filter are computable though.Thank you sir... I was hoping for the exact opposite, but as always... LOL Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
utc_pyro Posted August 31, 2018 Share Posted August 31, 2018 If you need a new bucket with a better pump, get on eBay and grab an ‘08-now STI fuel pump asembaly. I’ve gotten them for around ~$50 and they work in our cars. Link to comment Share on other sites More sharing options...
Scottydunno Posted September 1, 2018 Author Share Posted September 1, 2018 If you need a new bucket with a better pump, get on eBay and grab an ‘08-now STI fuel pump asembaly. I’ve gotten them for around ~$50 and they work in our cars.My plan is to upgrade the pump to either a walbro 255 or an aem 320. My power goal is 300-325 at the wheels.... reliably.. LOL Will that STI pump do what I need? Or should I stick to my plan??? Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
Scottydunno Posted February 10, 2019 Author Share Posted February 10, 2019 Dredging up from the depths... Definitely going with the AEM pump. Does anyone have a P/N for the pump to get??? Sent from my SM-N960U using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted February 10, 2019 Share Posted February 10, 2019 Just google AEM320 fuel pump I believe that's what my Tuner uses. Ok so I got up from my chair, went upstairs and got the box. AEM # 50-1215 FP KIT IN TANK ALC 320LPHW/HKS Bar code 8 40879 02445 1 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Scottydunno Posted February 10, 2019 Author Share Posted February 10, 2019 Just google AEM320 fuel pump I believe that's what my Tuner uses. Ok so I got up from my chair, went upstairs and got the box. AEM # 50-1215 FP KIT IN TANK ALC 320LPHW/HKS Bar code 8 40879 02445 1That's exactly why I ask! I've been googling all day of and on yesterday with no direct answers... hell, that PN never even came up either... Thank you again!!! Sent from my SM-N960U using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted February 10, 2019 Share Posted February 10, 2019 Your welcome. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
KRYPTO Posted February 14, 2019 Share Posted February 14, 2019 Does that AEM pump need wires spliced into factory harness? I seen a vid awhile ago that you have to buy the DW or Walbro install kit for the correct connector, although I do not know what kit number. Also, the factory power supply is relayed and computer controlled voltage per fuel needed? Link to comment Share on other sites More sharing options...
Code Posted February 14, 2019 Share Posted February 14, 2019 Get the iwire fuel pump relay kit. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
KRYPTO Posted February 14, 2019 Share Posted February 14, 2019 Get the iwire fuel pump relay kit. $250 Link to comment Share on other sites More sharing options...
Code Posted February 14, 2019 Share Posted February 14, 2019 It’s not cheap but it works and is quick and clean to install. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
