GTEASER Posted April 6, 2018 Share Posted April 6, 2018 Hey guys, just want some thoughts to make sure I am not missing anything. EJ255 motor so essentially the same as ours, but obviously small differences like I don't need to remove the turbo, and the accessory belt system is not the same. The motor has 50k miles on it, so I am going to inspect the timing belt and tensioner when I get in there. Those will NOT be replaced if they look good but WILL BE if I have any concerns. Parts I bought....all OEM of course. -water pump -water pump gasket -thermostat -thermostat gasket -seal that goes on the left side of the water pump -stretch belt (ac to crank pulley) -2 small water hoses that go between pump and other water pipes -Company 23 crank pulley tool -Company 23 stretch belt tool -Company 23 Cam Lock tool Do I need any sealant for the water pump gasket? Anything else? I will replace coolant with distilled water for now until I am sure there are no leaks, and then get the Subaru Coolant once that is confirmed. Thanks! GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Becks1818 Posted April 6, 2018 Share Posted April 6, 2018 Hey guys, just want some thoughts to make sure I am not missing anything. EJ255 motor so essentially the same as ours, but obviously small differences like I don't need to remove the turbo, and the accessory belt system is not the same. The motor has 50k miles on it, so I am going to inspect the timing belt and tensioner when I get in there. Those will NOT be replaced if they look good but WILL BE if I have any concerns. Parts I bought....all OEM of course. -water pump -water pump gasket -thermostat -thermostat gasket -seal that goes on the left side of the water pump -stretch belt (ac to crank pulley) -2 small water hoses that go between pump and other water pipes -Company 23 crank pulley tool -Company 23 stretch belt tool -Company 23 Cam Lock tool Do I need any sealant for the water pump gasket? Anything else? I will replace coolant with distilled water for now until I am sure there are no leaks, and then get the Subaru Coolant once that is confirmed. Thanks!Spray down the timing cover bolts with PBblaster. A bottom one broke on me and one was seized onto the metal sleeve the bolt sits in and ended up breaking a chunk off the cover when I went to turn it out. Other than that the list looks complete. Link to comment Share on other sites More sharing options...
dgoodhue Posted April 6, 2018 Share Posted April 6, 2018 Subaru recommends a sealant on the waterpump gasket for 5th Gen, but from what I read it was more to keep the gasket from falling off while installing. I will do that on my next water pump installation. Upon initial inspection, my OEM timing belt and idler pulleys, & tensioner all looked pretty good with 108k miles on them. I imagine my car had a lot of highway and faster rural roads miles which is what my car is getting these days. Link to comment Share on other sites More sharing options...
GTEASER Posted April 6, 2018 Author Share Posted April 6, 2018 Spray down the timing cover bolts with PBblaster. A bottom one broke on me and one was seized onto the metal sleeve the bolt sits in and ended up breaking a chunk off the cover when I went to turn it out. Other than that the list looks complete.With the fair weather and lack of rust here, and since the motor was just rebuilt back in June of 2015, I probably don't have to worry too much about the need to spray things down with PB. But noted anyways, thanks! GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Shadow_419 Posted April 6, 2018 Share Posted April 6, 2018 Looks good to me. You should have less issues with seized bolts due to the climate but some pb blaster like mentioned isn't a bad idea. O-rings for the Avcs covers if you're inclined. Link to comment Share on other sites More sharing options...
Rhitter Posted April 6, 2018 Share Posted April 6, 2018 So, if you don't replace the timing belt and tensioner you will need to be back in there in 50k to replace them. If you do them now, you are good for another 100k. The FSM does not call for sealant. However, when my engine was rebuilt sealant was used, when my water pump went (15k later) it was a pain to clean the sealant off. Interestingly it was on a rebuilt motor that my Gates water pump failed too. I didn't add any and just used the gasket and so far no leaks (15k later) My OBXT build Link to comment Share on other sites More sharing options...
GTEASER Posted April 6, 2018 Author Share Posted April 6, 2018 So, if you don't replace the timing belt and tensioner you will need to be back in there in 50k to replace them. If you do them now, you are good for another 100k. The FSM does not call for sealant. However, when my engine was rebuilt sealant was used, when my water pump went (15k later) it was a pain to clean the sealant off. Interestingly it was on a rebuilt motor that my Gates water pump failed too. I didn't add any and just used the gasket and so far no leaks (15k later)Thanks for the info! I'd rather not use sealant for the reasons you state. I'm pretty sure I have a Gates WP on there that was installed as part of the Gates kit when the motor was rebuilt with a new OEM shortblock by OutFront in 2015. I started smelling coolant on occasion about the time the motor had 10k miles on it. The leak has gotten progressively worse over the last 5k miles and it now drips even when warm. Prior to that, it only dripped once in a while, only when the motor was cold, for about the last year. I will verify if it's a Gates pump when I remove it. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
GTEASER Posted April 6, 2018 Author Share Posted April 6, 2018 I'm not gonna do the timing belt now if I don't have to because of budget. Another 50k miles is 2-1/2 years out in the future for me, so I will just do it then and I shouldn't have to do the water pump at that time so it should be pretty simple and not daunting since I am familiarizing myself with everything doing the water pump now. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
cww516 Posted April 6, 2018 Share Posted April 6, 2018 Find yourself a little pin so you can compress and lock the tensioner, that should make it a lot easier to get the timing belt off and back on. Probably also want a paint pen so you can mark the timing belt position on each pulley in at least 2 places (or just one, if you're not as paranoid as I was when I did the whole works on the Baja last year). Aligning timing marks on the pulleys with the block is all well and good, but if you can just line up the marks you made on the belt and on the pulleys, that's a good bit quicker. Now that I think of it, there's a fair chance you could do the water pump without having to take the timing belt off the pulleys, if you clamp it in place with visegrips and just pull it off of the water pump pulley. That may well become more of a pain than it's worth, though. Also, dunno how new your alternator belt is, but if you're replacing the A/C compressor belt, and you have to peel both off anyway, it could be worth replacing it as well. Not sure how necessary the tool really is if you don't have it already- it's easy enough to get to the tension adjuster, and you're probably going to need to adjust it after the new belt stretches a little anyway. Link to comment Share on other sites More sharing options...
Rhitter Posted April 6, 2018 Share Posted April 6, 2018 I'm not gonna do the timing belt now if I don't have to because of budget. Have you considered getting your kid into cheaper hobbies? Like cloud watching? My OBXT build Link to comment Share on other sites More sharing options...
Scubaboo Posted April 6, 2018 Share Posted April 6, 2018 I was gonna say do the timing belt and related while you're in because I recall aside from the mileage there is a time recommendation on it from Subaru (7 years I think), but I see you say it was part of the 2015 rebuild so you should be good to go with an inspection. I would have replaced the water pump during the rebuild so I wouldnt have to worry about opening the timing case for a long time. Good luck getting your Foz sorted out! Link to comment Share on other sites More sharing options...
GTEASER Posted April 6, 2018 Author Share Posted April 6, 2018 Find yourself a little pin so you can compress and lock the tensioner, that should make it a lot easier to get the timing belt off and back on. Probably also want a paint pen so you can mark the timing belt position on each pulley in at least 2 places (or just one, if you're not as paranoid as I was when I did the whole works on the Baja last year). Aligning timing marks on the pulleys with the block is all well and good, but if you can just line up the marks you made on the belt and on the pulleys, that's a good bit quicker. Now that I think of it, there's a fair chance you could do the water pump without having to take the timing belt off the pulleys, if you clamp it in place with visegrips and just pull it off of the water pump pulley. That may well become more of a pain than it's worth, though. Also, dunno how new your alternator belt is, but if you're replacing the A/C compressor belt, and you have to peel both off anyway, it could be worth replacing it as well. Not sure how necessary the tool really is if you don't have it already- it's easy enough to get to the tension adjuster, and you're probably going to need to adjust it after the new belt stretches a little anyway.The alternator belt is a year old. The AC belt is a stretch belt, so no tension adjuster, I'm gonna need the tool to get the new one on. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
GTEASER Posted April 7, 2018 Author Share Posted April 7, 2018 I was gonna say do the timing belt and related while you're in because I recall aside from the mileage there is a time recommendation on it from Subaru (7 years I think), but I see you say it was part of the 2015 rebuild so you should be good to go with an inspection. I would have replaced the water pump during the rebuild so I wouldnt have to worry about opening the timing case for a long time. Good luck getting your Foz sorted out!I didn't do the rebuild, a well respected shop did it for the previous owner, I got the car with 45k miles on the chassis and 1500 miles on the motor. I'm pretty sure they did replace the water pump at the rebuild, but I think they used a Gates water pump and those have been known lately for failing early. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
dgoodhue Posted April 7, 2018 Share Posted April 7, 2018 The FSM does not call for sealant. I am not trying to cause an argument, but the 2012 Legacy FSM does. See step 1 notes. Edit: Rhitter, I think you're right. The sealant is a gasket. Link to comment Share on other sites More sharing options...
BBPeik Posted April 7, 2018 Share Posted April 7, 2018 I would use some sealant as well. It is worth while insurance and if the pump fails the sealant really is pretty easy to get off later. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
DrD123 Posted April 7, 2018 Share Posted April 7, 2018 I am not trying to cause an argument, but the 2012 Legacy FSM does. See step 1 notes. By sealant, subaru is referring to the second gasket, I think. Still - a couple dots of permatex to hold it in place as an assembly aid is never a bad idea Link to comment Share on other sites More sharing options...
FLlegacy Posted April 7, 2018 Share Posted April 7, 2018 I would smear the sealant on so it is barely there but there nonetheless, no sense in concerning yourself with removing a bit of sealant 50k+ miles into the future Be very careful compressing that tensioner, use the fsm recommended method, in my forester it was supposed to take a few minute to compress it fully, so it was a painfully slow process. Link to comment Share on other sites More sharing options...
dgoodhue Posted April 7, 2018 Share Posted April 7, 2018 By sealant, subaru is referring to the second gasket, I think. Still - a couple dots of permatex to hold it in place as an assembly aid is never a bad idea I think you're right about the sealant. Link to comment Share on other sites More sharing options...
GTEASER Posted April 7, 2018 Author Share Posted April 7, 2018 I have the little seal part. Thanks guys! GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Scubaboo Posted April 7, 2018 Share Posted April 7, 2018 I didn't do the rebuild, a well respected shop did it for the previous owner, I got the car with 45k miles on the chassis and 1500 miles on the motor. I'm pretty sure they did replace the water pump at the rebuild, but I think they used a Gates water pump and those have been known lately for failing early. I see, sorry to hear that. I heard a bit about the Gates kits now having China parts but I thought the pumps were still good to go. So what is the way to go now with timing belt/water pump service? All OE only? Link to comment Share on other sites More sharing options...
GTEASER Posted April 7, 2018 Author Share Posted April 7, 2018 Personally I would go OE. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Scubaboo Posted April 8, 2018 Share Posted April 8, 2018 ^Duly noted. Appreciate you sharing your experience! Link to comment Share on other sites More sharing options...
dgoodhue Posted April 8, 2018 Share Posted April 8, 2018 I'm pretty sure they did replace the water pump at the rebuild, but I think they used a Gates water pump and those have been known lately for failing early. If they used a Gates water pump, you may want to also replace the tensioner while you're in there. Link to comment Share on other sites More sharing options...
GTEASER Posted April 10, 2018 Author Share Posted April 10, 2018 If they used a Gates water pump, you may want to also replace the tensioner while you're in there. Good point. Maybe I should just do the belt and tensioner while in there. Hmmmm..... GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
creep_nu Posted April 10, 2018 Share Posted April 10, 2018 Good point. Maybe I should just do the belt and tensioner while in there. Hmmmm..... it's like changing the throw out bearing but not changing the clutch, you might as well just do it while you're in there so you don't have to do all the labor again. Link to comment Share on other sites More sharing options...
