Cup_of_Joe Posted February 3, 2016 Share Posted February 3, 2016 Just wondering what everyone thinks about these. I have the base model, so no fogs at the moment and I was planning on grabbing the OEMS eventually. These are cheaper. http://m.ebay.com/itm/2x-LED-Daytime-Running-Fog-Lights-Lamp-DRL-Angel-Eyes-For-Subaru-Legacy-2010-12-/281909965047?nav=SEARCH Sent from my LG-ls990 using Tapatalk Link to comment Share on other sites More sharing options...
blklgt05 Posted February 3, 2016 Share Posted February 3, 2016 won't fit, the end mod journal Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted February 3, 2016 Author Share Posted February 3, 2016 won't fit, the end How come? Sent from my LG-ls990 using Tapatalk Link to comment Share on other sites More sharing options...
jackal8788 Posted February 3, 2016 Share Posted February 3, 2016 That's a JDM front end, not USDM. VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
testa422 Posted February 3, 2016 Share Posted February 3, 2016 ^this Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted February 3, 2016 Author Share Posted February 3, 2016 Ohhh.. Well then. Back to OEMS with hids Sent from my LG-ls990 using Tapatalk Link to comment Share on other sites More sharing options...
DugsSin Posted February 3, 2016 Share Posted February 3, 2016 I would skip the OEM's they are mostly for show even with bulb upgrades. These are lights https://www.theretrofitsource.com/complete-headlight-fog-light-housings/morimoto-xb-led-fog-lights-type-s.html#. I love mine with yellow lamix overlays. Oh with HID upgrade that's different. Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted February 3, 2016 Author Share Posted February 3, 2016 Those LEDs look nice, and a little cheaper than OEMS, but doesn't come with the housing. Sent from my LG-ls990 using Tapatalk Link to comment Share on other sites More sharing options...
Zee199969 Posted February 3, 2016 Share Posted February 3, 2016 are you looking for functional fogs or just some front end bling? I've got this that replaces my DRL function http://www.osram.com/osram_com/news-and-knowledge/automotive-special/automotive-design-lamps---eye-catchers-with-that-stylish-look/automotive-lighting---stylish-and-trendy/daytime-running-light-using-leds/ledriving-px-5---daytime-running-light-for-retrofit/index.jsp My "Build" Link to comment Share on other sites More sharing options...
Picky1 Posted February 3, 2016 Share Posted February 3, 2016 I would skip the OEM's they are mostly for show even with bulb upgrades. These are lights https://www.theretrofitsource.com/complete-headlight-fog-light-housings/morimoto-xb-led-fog-lights-type-s.html#. I love mine with yellow lamix overlays. I had the OEM fogs that really didn't do much and after one of the lights was taken out back a rock or something last winter I replaced them with the Morimoto's with yellow Lamix. Actually I got lucky and found someone selling a set of the Morimoto's with the Lamix and picked them up for $100 shipped. Link to comment Share on other sites More sharing options...
Ellesedil Posted February 3, 2016 Share Posted February 3, 2016 I too have the Morimoto fogs. One of the OEM fogs had a broken lense so I decided to upgrade. I ended up ordering some tinted laminx instead of going with yellow. They're still the brightest lights on my car right now, despite the slightly darker shade. Couldn't be happier. Link to comment Share on other sites More sharing options...
NorCal1657615595 Posted February 3, 2016 Share Posted February 3, 2016 Are these Morimotos direct swap in for those that have the OEM Fogs? Do the current housings/bezel just pop out or do we have to remove the bumper? Link to comment Share on other sites More sharing options...
Zee199969 Posted February 3, 2016 Share Posted February 3, 2016 Are these Morimotos direct swap in for those that have the OEM Fogs? Do the current housings/bezel just pop out or do we have to remove the bumper? the bezels pop out with the help of a plastic pry tool My "Build" Link to comment Share on other sites More sharing options...
Ellesedil Posted February 3, 2016 Share Posted February 3, 2016 Are these Morimotos direct swap in for those that have the OEM Fogs? Do the current housings/bezel just pop out or do we have to remove the bumper? Yes, they are a direct swap. No, you do not have to remove the bumper or remove the bezel. There are detailed directions on installing them elsewhere on the forum; you'll have to search for them. In general, here is what I did. I removed a couple of popits from the plastic piece that connect to the bumper corners under the car. You don't have to remove the plastic piece, you just need to pry the plastic away to create enough space to get your hand and the new fogs in there. If I recall, that took removing about 5-7 popits. That's it. Remove the screw that's holding in the original fog, unplug the fog wiring, and remove it. Slide the connector leads of the new fog light into the included connector housing (ensure that the polarities are correct before locking the leads in place). Put the new fog into the car, lining up the holes of the fog with the plastic dimples in the housing/bezel. Replace the screw, fastening the fog light to the housing/bezel. Plug in fog light. Tuck wires away. Refasten popits. Repeat with the other side. The first fog light took me over an hour to install while I figured everything out. The second fog light took 10 minutes. I did this with the car on the ground. Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted February 3, 2016 Author Share Posted February 3, 2016 For my base model with no fogs, do I need to pick up housings off eBay for the morimotos? Yes, they are a direct swap. No, you do not have to remove the bumper or remove the bezel. There are detailed directions on installing them elsewhere on the forum; you'll have to search for them. In general, here is what I did. I removed a couple of popits from the plastic piece that connect to the bumper corners under the car. You don't have to remove the plastic piece, you just need to pry the plastic away to create enough space to get your hand and the new fogs in there. If I recall, that took removing about 5-7 popits. That's it. Remove the screw that's holding in the original fog, unplug the fog wiring, and remove it. Slide the connector leads of the new fog light into the included connector housing (ensure that the polarities are correct before locking the leads in place). Put the new fog into the car, lining up the holes of the fog with the plastic dimples in the housing/bezel. Replace the screw, fastening the fog light to the housing/bezel. Plug in fog light. Tuck wires away. Refasten popits. Repeat with the other side. The first fog light took me over an hour to install while I figured everything out. The second fog light took 10 minutes. I did this with the car on the ground. Sent from my LG-ls990 using Tapatalk Link to comment Share on other sites More sharing options...
Ellesedil Posted February 3, 2016 Share Posted February 3, 2016 For my base model with no fogs, do I need to pick up housings off eBay for the morimotos? Sent from my LG-ls990 using Tapatalk I would assume so, but I'm not sure. I suggest seaching the forums, as I'm positive at least one person did a full write-up about installing these guys into a Legacy that didn't come with fogs from the factory. A notable thing to keep in mind is your switch. You'll need one. Link to comment Share on other sites More sharing options...
foxrider28 Posted February 3, 2016 Share Posted February 3, 2016 Yup need the switch and the bezels. Non fog cars won't have mounts. http://www.car-part.com You can find everything you need there for cheap Link to comment Share on other sites More sharing options...
FLlegacy Posted February 3, 2016 Share Posted February 3, 2016 Also the relay. Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted February 3, 2016 Author Share Posted February 3, 2016 OEM with hids aren't as good as the morimotos? Sent from my LG-ls990 using Tapatalk Link to comment Share on other sites More sharing options...
NorCal1657615595 Posted February 3, 2016 Share Posted February 3, 2016 Here's the detailed install and parts. http://legacygt.com/forums/showthread.php/morimoto-xb-led-fog-install-theretrofitsource-233152.html?t=233152&highlight=morimoto+fog Link to comment Share on other sites More sharing options...
testa422 Posted February 4, 2016 Share Posted February 4, 2016 Hid in a small dog housing is not good in my opinion. Too much light for that small of a housing. I also have the morimotos and LOVE them Link to comment Share on other sites More sharing options...
Hanger Posted February 4, 2016 Share Posted February 4, 2016 I work for a company name Winjet Automotive. http://www.winjetinc.com We're currently developing a fog light kit for 2010-2012 & 2013-2014 Legacy. Comes with lamps, bezels, bulbs, wiring kit+Relay & switch Bulb type is H11 55W Test fitting stage is all done, so we should have them available mid 2016. Estimated price $79.95 ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted February 4, 2016 Author Share Posted February 4, 2016 Alright alright, only the best for my baby, so morimotos, plus the housing, switch, relay. Sent from my LG-ls990 using Tapatalk Link to comment Share on other sites More sharing options...
Picky1 Posted February 4, 2016 Share Posted February 4, 2016 Another option that I looked at where these: http://www.ft86speedfactory.com/olm-vision-drl-led-fog-light-housings-1821.html#.VrK28aQo7cs These are for a BRZ/FRS or WRX, they basically look like they are the same size as the 5th Gen Legacy fog light and would double as your DRL. Link to comment Share on other sites More sharing options...
blklgt05 Posted February 4, 2016 Share Posted February 4, 2016 I have a set of OE fogs with DIY fully covered lamin-X yellow vinyl, and 1 month old 3000K morimoto HID bulbs. I decided to change the look and got the LED fogs recently. One of the foglight housing have 1 tab broke off during my original install, but it does not affect it being secured onto the bumper and I've had them for many years. So only thing you need to buy are foglight bumper covers, harness and ballast from retrofitsource. LMK if interested. mod journal Link to comment Share on other sites More sharing options...
