Tobino Posted February 11, 2015 Share Posted February 11, 2015 I've got a 2005 LGT wagon with what appears to be stock struts. The rear of the car is sitting lower than the front. I was curious if I could put WRX springs in the front to lower just the front about an inch. If so which years and top hats would I need? I'm also aware there are rear struts spacers made to fix the sag in the rear. I might look into that more but I like how low the back is and would love to get the front at that level as well. Thanks! Link to comment Share on other sites More sharing options...
Rhitter Posted February 12, 2015 Share Posted February 12, 2015 No, but you could get some legacy springs to lower the front. My OBXT build Link to comment Share on other sites More sharing options...
Holla Posted February 12, 2015 Share Posted February 12, 2015 Wrx springs aren't going to work. I run Epic springs in the front and oem in the rear to give the car a slightly raked stance but retaining an oem like ride quality. I tired a few different suspension setups but this is what works best for my dd wagon. Another thing to note is if your rear shocks are old the rear will sag even more. I was surprised how much a fresh set of shocks raised the rear of my car with the oem springs. Link to comment Share on other sites More sharing options...
magnusonsubie Posted February 12, 2015 Share Posted February 12, 2015 I've got Koni's and H&R springs on my wagon with 3/8 saggy butt spacers and it sits quite level at a very reasonable height. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
Tobino Posted February 13, 2015 Author Share Posted February 13, 2015 Thanks guys as per usual very helpful! Link to comment Share on other sites More sharing options...
