nomoreS4 Posted April 30, 2005 Share Posted April 30, 2005 After having it sitting in my garage since January, finally managed to install my JDM 20mm rear sway. Took me less than an hour, including cleanup. Luckily, I have a buddy with a hoist -- I wouldn't have wanted to wrestle with the sway bar with the car up on ramps! When I bought the sway, I also got the AVO adjustable endlinks, which I thought would be good to install since they're much beefier than the stock links. I tried adjusting them to make them the same length as the stock links, but found that there really wasn't much thread left on them when adjusted out...I guess they're really only meant for lowered suspensions. So, I'll hang on to these for when/if I lower. Wow...the 20mm sway really cleaned up a lot of rear end slop...noticeably tighter than before, not just cornering, but even feels more precise when going over bumps. Highly recommended! Link to comment Share on other sites More sharing options...
Joe05GTMT Posted May 1, 2005 Share Posted May 1, 2005 Pictures pleases :-) Link to comment Share on other sites More sharing options...
rc0032 Posted May 1, 2005 Share Posted May 1, 2005 Pictures pleases :-)Here are some on the XT Link to comment Share on other sites More sharing options...
mwiener2 Posted May 1, 2005 Share Posted May 1, 2005 I hear about alot of people swapping onthe JDM rear sway.... waht about the front? Is the JDM front the same as ours and that's why noone is doing it? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
B4_Maniac Posted May 1, 2005 Share Posted May 1, 2005 It's about dang time.... Link to comment Share on other sites More sharing options...
apexjapan Posted May 1, 2005 Share Posted May 1, 2005 Yes, the USDM and the JDM front swaybar is the same size - so not much point in swapping out. If you were going to swap out for an aftermarket swaybar in the front, I'd suggest getting the same makers aftermarket rear at the same time, better chance that the car will retain balance front to rear that way. Cheers, Paul Hansen http://www.avoturboworld.com http://www.sevenphotos.com Link to comment Share on other sites More sharing options...
nomoreS4 Posted May 1, 2005 Author Share Posted May 1, 2005 It's about dang time.... Hey...I know...but gotta remember, it's only been a few weeks since the snow melted here. I had my snows/rims on all winter...wanted to drive a few weeks on summer rubber so I could do an appropriate comparision between stock and the new sway. Trust me, it's been a frustrating wait, but I'm really enjoying the difference in ride quality now! Link to comment Share on other sites More sharing options...
Unilat Posted May 1, 2005 Share Posted May 1, 2005 Good for you! Mine is still sitting in the garage, uninstalled! Link to comment Share on other sites More sharing options...
firedawgs Posted May 1, 2005 Share Posted May 1, 2005 I was very pleased with the results of swapping out the rear sway bar for the JDM bar. Next will be the end links. Updated my vBGarage: Link to comment Share on other sites More sharing options...
jedd Posted May 3, 2005 Share Posted May 3, 2005 any thoughts between the JDM and the Perrin? Maybe a case of 6 of one and half a dozen of the other? Link to comment Share on other sites More sharing options...
firedawgs Posted May 3, 2005 Share Posted May 3, 2005 Big difference. The perrin is adjustable from stock 17mm to 22mm. The JDM is straight 20mm. Perrin is a little higher in price. Both come with Poly bushings. You decide. Updated my vBGarage: Link to comment Share on other sites More sharing options...
drewster Posted May 11, 2005 Share Posted May 11, 2005 just placed an order for a jdm 20mm bar. Link to comment Share on other sites More sharing options...
nomoreS4 Posted May 11, 2005 Author Share Posted May 11, 2005 just placed an order for a jdm 20mm bar. Get ready for a BIG grin! Link to comment Share on other sites More sharing options...
SBT Posted May 12, 2005 Share Posted May 12, 2005 Pictures pleases :-) Here's some pictures and walkthrough of my JDM 20mm install. Also notice my comment on post #13 about the AVO end links, similar to nomoreS4's above. http://legacygt.com/forums/showthread.php?t=10073 SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
nomoreS4 Posted May 12, 2005 Author Share Posted May 12, 2005 Here's some pictures and walkthrough of my JDM 20mm install. Also notice my comment on post #13 about the AVO end links, similar to nomoreS4's above. http://legacygt.com/forums/showthread.php?t=10073 SBT Dale, I printed off your instructions and referred to them constantly during my install...everything just as you stated, THANKS! Link to comment Share on other sites More sharing options...
Leonardo Posted May 12, 2005 Share Posted May 12, 2005 where can I order it? Link to comment Share on other sites More sharing options...
drewster Posted May 12, 2005 Share Posted May 12, 2005 ordered mine from here: http://www.avoturboworld.com/avoshop/ Link to comment Share on other sites More sharing options...
SBT Posted May 13, 2005 Share Posted May 13, 2005 Yeah, Paul at AvoTurboWorld hooked a bunch of us up with a group buy late last year. Mine came in during the torrential downpour and flooding in SoCal on New Year's Eve and it took me to March to get it on the car because of all the rain and the fact that my MG project and E30 rebuild are clogging up the garage. Very straight forward and easy and noticed an immediate tightening up of the whole rear end. Like the fact that it's an actual Subaru bar so the fit is perfect. Getting performance springs/struts on is my next goal so I'll probably go with the STI Pinks initially and then upgrade from there (if necessary) to either a set of STI Coilovers or with a set of JDM Bilstein Rev B, Spec B takeoffs. nomoreS4 - glad the writeup was helpful. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Deer Killer Posted May 13, 2005 Share Posted May 13, 2005 My guess is we didn't get it so we wouldn't kill ourselves with our soft suspension and lift-off oversteer. Someone wanna try it and see what happens? Link to comment Share on other sites More sharing options...
SBT Posted May 13, 2005 Share Posted May 13, 2005 Did get to try out the stock one for about 2500 miles before putting on the JDM 20mm one. I actually felt like I could get the back end to drift out a little better with the stock bar and lift off throttle oversteer in the turns resulted in porpoising that has all but disappeared with the 20mm upgrade. Also, went out for two weekends in a row into the mountains, one with the wife so much less spirited driving, and then the next weekend on a fun run with much more spirited driving over the exact same road. Both drives were with the 20mm and from my experience on the fun run, and the stock tires set to 38F/36R, the car is a canyon carver and very drama free even when pushed hard into the turns. This was through some uphill/downhill off-camber turns where touching the brakes at those speeds would really unbalance the car and rapidly make it unstable. People behind me commented on how flat the car transitioned (this is a wagon) and how stable it seemed through the corners. From behind the wheel it felt the same. Those ahead were amazed at how quickly it got through the turns compared to their stock sedans IMHO - the SOJ 20mm RSB seems to be the best mix of performance improvement (bar-wise) and worry free handling. As I mentioned it fits perfectly with no problems, and puts an even bigger grin on your face when you upgrade. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
hotrodwagon Posted May 13, 2005 Share Posted May 13, 2005 Ditto Subietonic's comments. Took my wagon to the track last Sunday and there was no drama anymore throwing it into those corners either. Link to comment Share on other sites More sharing options...
Unilat Posted May 15, 2005 Share Posted May 15, 2005 On 5/1 I said: Good for you! Mine is still sitting in the garage, uninstalled! Problem resolved! In spite of other's comments to the contrary, I really wasn't expecting a big change - wrong! The car immediately seemed sharper and communicates more feel from the rear - I was able to determine this all within two blocks of my house. This is a worthwhile mod - cheap and easy (except for getting the bar out - takes some patience). One reason I was putting off new tires was that the car felt too loose for me to comfortably use any extra traction. I don't think that will be an issue any longer. As an interesting data point - I ran a couple skidpad tests before and after the install. The average of clockwise and counter before and after was a surprisingly high sustained .9 g. The biggest difference was that I didn't have to look up and over the side of the car after the install! Link to comment Share on other sites More sharing options...
Xantium Posted May 22, 2005 Share Posted May 22, 2005 the 2.5i has a 1mm smaller in diamter front sway than the jdm.. the gt is the same though. Link to comment Share on other sites More sharing options...
jedd Posted May 23, 2005 Share Posted May 23, 2005 Do you suggest using the JDM endlinks? Link to comment Share on other sites More sharing options...
Leonardo Posted May 23, 2005 Share Posted May 23, 2005 I would go with Perrin end links if you are going to buy any. I still have to order my rsb! Link to comment Share on other sites More sharing options...
