jojorios Posted April 8, 2017 Share Posted April 8, 2017 I had a mushroom of battery acid on the positive terminal so i bought a new Exide group 34 battery. Took out the old and replaced the new. When i sat in the car and turn on my lights everything was working as normal. The second I went to start it nothibg happend. All the lights went dead and now the car does absolutely nothing i tried putting the old battery to see if that was it and same thing nothing. Kinda freaking out. Not sure which of all the fuses or what epse to check. Any suggestions will be greatly appreciated Link to comment Share on other sites More sharing options...
Shadow_419 Posted April 8, 2017 Share Posted April 8, 2017 Double check that nothing is shorting out. The main fuse is pretty obvious but it's also marked on the fuse box cover. I would start there. Link to comment Share on other sites More sharing options...
FLlegacy Posted April 8, 2017 Share Posted April 8, 2017 I don't know if there are fusible links in the wiring to the main fuse panel but you might give that a look as well. Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
BBPeik Posted April 8, 2017 Share Posted April 8, 2017 I would look for corrosion in the cables. Sounds like as soon as you put any kind of load there is not a good enough connection to make anything work. I have seen corrosion work its way back into the cable and really screw things up. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
jojorios Posted April 8, 2017 Author Share Posted April 8, 2017 I think it may be a short someplace. I removed all the wiring minus the main ground and power and i get power again but the second I go to crank it nothing. I then have to disconnect everything again and connect then positive then the negative to "reset it" l. Would an after market alarm have its own wire connected to the battery. Im wondering if its fallen someplace and i need to connect it. Link to comment Share on other sites More sharing options...
jojorios Posted April 8, 2017 Author Share Posted April 8, 2017 Yeah, it was really corroded but i used the car no more than 4 hours ago without a problem. Link to comment Share on other sites More sharing options...
jojorios Posted April 8, 2017 Author Share Posted April 8, 2017 I'm starting to suspect it's the terminal i bought. And of course i posted tue wrong youtube video. But I found the issue. It was the terminal. I got a different one from autozone and popped it on. Car started instantly. Sent from my SM-G935F using Tapatalk Link to comment Share on other sites More sharing options...
jojorios Posted April 9, 2017 Author Share Posted April 9, 2017 And thank you to everyone with the suggestions. I was terrified that it was the biu when is was completely dead. Sent from my SM-G935F using Tapatalk Link to comment Share on other sites More sharing options...
