SLC 801 Posted June 29, 2011 Share Posted June 29, 2011 So I have a 3 psi differential between my 3rd cylinder and the other 3, I need to get the problem fixed, and it was my understanding the entire engine needed to come out, does anyone have any recommendations of what to do to it as far as upgrades are concerned? I have 4000 to spend in total, So i figure 2000 to take the engine out and fix it, 2000 for fun. Thoughts? Thanks for the help guys and Gals! Link to comment Share on other sites More sharing options...
robinlsb Posted June 29, 2011 Share Posted June 29, 2011 3 psi??????? "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
bmx045 Posted June 29, 2011 Share Posted June 29, 2011 What are all the psi's? Link to comment Share on other sites More sharing options...
madcatz Posted June 29, 2011 Share Posted June 29, 2011 wait...you have a 3psi difference on a Compression test on the #3 cylinder? What is the overall compression of the cylinders.....they all will vary in pressure......about 5% is ok between cylinders......3psi is not above your 5% unless your only holding 10psi a cylinder, then I dont even know how you turn the engine over and you probably have a hole in your piston -Travis Rob (rao) you're a fine gentleman, thanks I guess. Link to comment Share on other sites More sharing options...
LSxFTW Posted June 29, 2011 Share Posted June 29, 2011 3 psi??????? wait...you have a 3psi difference on a Compression test on the #3 cylinder? What is the overall compression of the cylinders.....they all will vary in pressure......about 5% is ok between cylinders......3psi is not above your 5% unless your only holding 10psi a cylinder, then I dont even know how you turn the engine over and you probably have a hole in your piston What they said. A 3psi difference on a compression test is nothing to worry about. Who said that you need to "get the problem fixed"?? Link to comment Share on other sites More sharing options...
bmx045 Posted June 29, 2011 Share Posted June 29, 2011 What they said. A 3psi difference on a compression test is nothing to worry about. Who said that you need to "get the problem fixed"?? Probably a mechanic without much business. Link to comment Share on other sites More sharing options...
SLC 801 Posted July 1, 2011 Author Share Posted July 1, 2011 thanks for the intel guys, I'm no good engine stuff, and new to this whole world, It was the Subaru dealership that said I should have it fixed, and also I'm running 16 mpg even though i drive like an old man. My engine shakes when it idles even with 91 octane and sea foam additive, and the check engine light comes on and off intermittently, which in turn doesn't let me use cruise control... That being said, i've gone to get other tests from other people, and they are saying it has something to do with my o2 sensor, or a sticky valve...? If this were the case what would that entail as far as repairs go? that being said what could I do to upgrade this system instead of just replacing it oem? the ECU? maybe some other things? would any one be so kind as to let me know their estimated cost for these repairs? I really appreciate the help... Thanks a lot! Link to comment Share on other sites More sharing options...
bmx045 Posted July 1, 2011 Share Posted July 1, 2011 the rough idle could be because of a vaccum leak, like a hose popped off somewhere around the intake manifold, get the computer read for the CEL codes, if we know what they are (and I think I do) it will help us more. could be time to change the spark plugs. we need to rule things out one at a time because a rough idle and bad mpg can result from a lot of different things. Link to comment Share on other sites More sharing options...
TRSCobra Posted July 1, 2011 Share Posted July 1, 2011 Go to autozone or advance and have them put a scan tool on the car, then write down codes (in a P#### format) and post them here so we have a better idea of what to look for. Link to comment Share on other sites More sharing options...
bakabakablah Posted July 2, 2011 Share Posted July 2, 2011 You don't need to go to Autozone to get your CELs checked out. Our cars have a code reader built in: 2005 2006+ Link to comment Share on other sites More sharing options...
frank_ster Posted July 3, 2011 Share Posted July 3, 2011 Prehaps you can put some sand in the cylinders that are high on compression Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
SLC 801 Posted July 3, 2011 Author Share Posted July 3, 2011 P0301 P0303 -Cylinder one and Cylinder three Misfire It says probable cause is... A) Leaking or blocked injector B) Ignition system malfunction affecting one cylinder C) Engine mechanical condition D) Valve adjustment needed P0463 Fuel level sensor circuit high input Probable cause... A) Open or short circuit condition B) Poor electrical connection C) Faulty fuel level sensor Also my right headlight flickers, and when i have my system turned up it appears to flicker to the heavy bass notes... Any clue on what I should do next? If so, any recommendations on how I should upgrade from oem when I am fixing these issues? Thank you again for your help I really appreciate it! Link to comment Share on other sites More sharing options...
charlie_sheen Posted July 3, 2011 Share Posted July 3, 2011 well, i would start by selling those subwoofers for money to put towards fixing your problems. Link to comment Share on other sites More sharing options...
bmx045 Posted July 3, 2011 Share Posted July 3, 2011 Misfires are a common topic on this forum, I'm sure you'll find a lotta info. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 5, 2011 Share Posted July 5, 2011 Don't be so worried about upgrading. Just find a good mechanic, (not the stealership) and get it fixed. Tell us where you live, may be someone can recommend somebuddy close to you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
