TMitchell Posted January 10, 2020 Share Posted January 10, 2020 Hi all, I couldn't find a thread for this, but let me know if I should be posting elsewhere. I bought my 2005 Legacy Sedan used in 2016 at around 180,000 miles. In the last two years, I've replaced the head gaskets in the engine twice due to leaks. The first repair was done at a general automotive repair shop in town. The second time I took it to a legitimate, authorized Subaru dealership and service center. I also had all of the engine seals re-done along with the head gasket. This was February 2018. Today (January 2020), I just took my car in for regular maintenance and was told there are leaks on my head gaskets again. I've probably only put in about 20,000-25,000 miles into the car since that previous head gasket replacement. I'm feeling pretty discouraged at this point and am wondering why this is happening again. Any thoughts on this? Is it worth maintaining this vehicle and going through another head gasket replacement? Is this normal for the 2005 Legacy model? I would appreciate any thoughts you have. Much thanks, and happy new year! Link to comment Share on other sites More sharing options...
awfulwaffle Posted January 10, 2020 Share Posted January 10, 2020 Was the head and block surfaces checked for finish/flatness both times? Adequately cleaned? Definitely not normal. Link to comment Share on other sites More sharing options...
apexi Posted January 10, 2020 Share Posted January 10, 2020 It could just be very minor seepage that is nothing to worry about. I'd be curious to see pictures. Link to comment Share on other sites More sharing options...
Nonamedude Posted January 10, 2020 Share Posted January 10, 2020 Have you had the engine overheat in that time period? Are they sure it's not a leaking valve cover gasket? I've seen people overheat their subaru's and get head gasket leaks after due to warping stuff. Really any vehicle with aluminum heads seems to do this from the way I hear it told. But otherwise, that seems abnormal. Link to comment Share on other sites More sharing options...
NORULZleggy Posted January 10, 2020 Share Posted January 10, 2020 Drove my 08 2.5i with a leaking head gasket for a year, then pulled the motor and put OEM MLS subie gaskets on myself and never had a problem. I thinks it might be time for true Subaru performance shop to look it over. It could be simple or short block time. Are they pulling the motor to do the gaskets? I have always been token the it the true way to do it or you will be having issues 30K or sooner down the road. Link to comment Share on other sites More sharing options...
gkinslow Posted January 10, 2020 Share Posted January 10, 2020 Would it not be under warranty from the last replacement? I assume this is an NA car? Link to comment Share on other sites More sharing options...
06RENN Posted January 11, 2020 Share Posted January 11, 2020 Not normal but if you do it again definitely have the surfaces checked. HBolts are also single use stretch to torque type but I know a lot of dealers reuse them. Arguments can be made for both cases but for a few $$ it's worth it. Link to comment Share on other sites More sharing options...
