ObiWanToby Posted June 7, 2015 Share Posted June 7, 2015 Was doing the easy 15 minute power streering flush today. I noticed what appears to be my exhaust manifold (exhaust pipe bottom of engine bay below the radiator fans) has a strange hole in it? Do these have heat shields on them? Strange thing is the car seems to run fine ... I took a picture. At the top is the accessory belt, at the bottom of the image you can see the radiator fan. http://i.imgur.com/7Leuvv4.jpg Where you see that rusted bolt, that appears to be a hole? It is difficult to tell if this is some outer coating or if it is an actual issue, especially with the car seeming normal. Any ideas with the pic? Link to comment Share on other sites More sharing options...
gto7419 Posted June 7, 2015 Share Posted June 7, 2015 That's just a heat shield. The manifold is actually really thick cast steel. I haven't heard of any failures of that part and I've been around Subaru's since 03. Link to comment Share on other sites More sharing options...
