dipren443 Posted March 19, 2019 Share Posted March 19, 2019 Ok folks, looking for some advice. I have an '05 Legacy GT wagon. Its been my trusty sidekick for going on 12 years now. I am not ready to replace it as I just put a brand new STi short block in along with some other upgrades. On to my main question. I currently have a set of JDM Spec B wagon Bilsteins on the car. They have now been on the car for about 140k miles I think. Its time to either replace or rebuild. The only issue I have is that I'd like the ride height to be a little lower. I am not against the idea of coilovers, but I've read enough on here that they aren't always the best setup. I like the ride to be firm but compliant. If I want the ride height a little lower, is that my only option? I think I could live with the rear height, its mostly the front that I am not a fan of. What about a different set of springs? Will they work well with the JDM Bilsteins? If so, what are the best options for springs? So I don't have to take the car out of commission, I think I'd likely buy a new set of jdm bilsteins instead of sending mine out for rebuilds. What springs would get me where I want and still work well with the Bilsteins? If not that, then what coilovers would be recommended? I'd rather pay for quality if that is a factor. Thanks in advance! Link to comment Share on other sites More sharing options...
Infosecdad Posted March 19, 2019 Share Posted March 19, 2019 I don't have any answers for you at the moment, but I'll be facing the same question in the next year or two, so I'm watching for answers and options :-D Link to comment Share on other sites More sharing options...
jrho Posted March 19, 2019 Share Posted March 19, 2019 It depends on how much you want to lower your car. If you're looking to lower your car by just a bit, STI pinks will lower 15mm and should match will with the JDM Bilsteins. Link to comment Share on other sites More sharing options...
dipren443 Posted March 19, 2019 Author Share Posted March 19, 2019 It depends on how much you want to lower your car. If you're looking to lower your car by just a bit, STI pinks will lower 15mm and should match will with the JDM Bilsteins. Is that 15mm on top of what the JDM Spec B springs dropped it? They lowered it a bit from stock already. 15mm on top of what I have now would probably be ideal. Link to comment Share on other sites More sharing options...
jrho Posted March 19, 2019 Share Posted March 19, 2019 Is that 15mm on top of what the JDM Spec B springs dropped it? They lowered it a bit from stock already. 15mm on top of what I have now would probably be ideal. I believe it's a 15mm from the JDM set up Link to comment Share on other sites More sharing options...
